no clutch pressure help!!!
I was driving home and gearing to 5th and clutch petal lost all pressure stuck to the floor i pulled it back up and it had some pressure I went to drive again lost it and this time I lost it for good I found a leak at the flare connecting to rubber house I got it replaced and no more leaking and bleeded the clutch kept the fluid topped off and kept trying still nothing checked both the master and slave cylinder to see if they were leaking and still no leaks I looked everywhere for thr hydrualic fluid to be leaking andbi cant find the problem I'm stumped does anyone know what it could be?
Posted from Evolutionm.net App for Android
Same thing happened to me, (03 OZ). I had to pump the clutch about 40 times to get enough pressure to put it into first. Ended up replacing the clutch and found my clutch was extremely overheated from previous owner. I had only had the car about a month.
chinalfr
16
Sep 24, 2003 03:24 PM
