starting problems
Old Apr 27, 2013 | 02:55 PM
addicted2speed's Avatar
starting problems
Hey All Having Starting Problems... For A Year And A half now. When I Yurn The Key It Goes Click. This Is My Third starter. Sometimes It Starts About 50% Of Thetime This Happens. My Alternator Still Charges, My Battery Isnt Dead But Im Guessing Itsnot Holding A Charge As Good As It Use To But Its only About 7Months Old And Im In Az. Have Hks 272 Cams And An Exedy Twin PlaTe Clutch With A New Fly Wheel...Would These Parts Cause Starting ToBe a Little Tough?? Im Thinking It Would Be But Not That Much. Please Someone Give Me Some Info
Old May 23, 2013 | 12:34 PM
donzilla2004's Avatar
Where are you getting your starters from?
Also check all your connections to and from the starter to the battery, check grounds first. Start with the very basics, make sure no wires show corrosion in or on them. It sounds elementary but you would be surprised what we find when servicing vehicles.
Check your battery and make sure it doesn't have a bad cell, even newer batteries can do that.
My 05 evo has 272 cams, and I always thought that it was my car, not my battery, it always had a slow crank, got a better battery and problem was solved.
However if you are having a no crank, no start condition it could be a lot of things, ignition switch, starter, loose terminal to a battery even.
Old Jun 21, 2013 | 09:39 AM
gsx1992's Avatar
I second the bad starter idea. Usually the $100 Autozone starters are junk after a short time.
Old Jun 21, 2013 | 09:43 AM
4bangn's Avatar
check your alternator fuse, if that's blown your alternator isn't charging your battery while you drive, had this happen to a friend of mine, we changed the battery and alternator and still wouldn't start til finally we checked the fuse for the alternator and found it blown, 4 dollar part was all it was
Old Jun 21, 2013 | 09:44 AM
meckert's Avatar
So what do you have in the way of a stereo and security system? Asking as these can cause a constant drain... which sounds like what you have to me. Find someone with some electrical know how and have them make a determination if you have active power when the ignition is off. My guess is something is staying on.
xuder
Jan 24, 2023 02:42 PM
hooliganSKATE
Aug 17, 2015 03:30 PM
bobby.is.rad
Mar 16, 2012 10:04 AM
HN7
Sep 5, 2011 01:15 PM
