RRM test pipe
Old Sep 22, 2002 | 10:35 PM
JohnMemorialHS's Avatar
RRM test pipe
I want something to replace my cat. converter, and RRM test pipe seem to be the only thing out there that won't set my second O2 sensor off. I'm pretty sure it's a bolt-on, because on the website it says keep the old cat for regular road use. I personally am looking for a permanent replacement, so is it possible to weld the RRM test pipe on?
Old Sep 22, 2002 | 11:05 PM
ROCK's Avatar
You can weld it on but it is not necessary. It comes with hardware needed to bolt on and alot easier to install your O2 sensor.
ROAD/RACE
http://www.roadracemotorsports.com/
Old Sep 23, 2002 | 12:07 AM
What does that mean? The O2 sensor comes with the test pipe or something? I thought the test pipe just comes with a hole that accomadates the O2 sensor
Old Sep 23, 2002 | 12:51 AM
Pimpson's Avatar
yeah it bolts in. But so does the OEM 2nd cat. It goes perfectly in place, along with a whole threaded for the o2 sensor. very easy install process, I recommend it.
Old Sep 23, 2002 | 07:27 AM
Joseanevo's Avatar
Dude do it with that you replace it when smoog test arrives replace it again don't weld ....
XxLaNcErGTSxX
Jul 9, 2008 07:46 PM
AutoSleeperOZ
Aug 13, 2004 05:26 PM
beanutoo
Lancer Engine Tech
10
Apr 18, 2004 07:35 PM
Ludz
Mar 25, 2004 01:39 PM
Scotty2Hottie
Lancer Engine Tech
15
Dec 29, 2003 03:32 AM
