Just got my Testpipe but.....
Old Jul 22, 2004 | 03:01 PM
fborg's Avatar
Angry Just got my Testpipe but.....
no one wants to install it. I went to 8 different Muffler shops and they told me that it's illegal to install it. So, can someone tell me where to go!!!!!!!!!??????????
Old Jul 22, 2004 | 03:04 PM
Iamkar33m's Avatar
1st of all this post is in the wrong place. A mod shall move it shortly. 2nd of all it is illegal for any muffler shop to tamper with vehicle emissions systems. They can get fined like $3,000 and lose their business license if they get caught tampering with a customer's emissions. Lastly it's so easy... just jack the car up or put it on a lift. Remove 4 bolts and out comes ur cat, be sure to unplug the sensor then put the testpipe in and put the sensor into the bung and put the 4 bolts back. Ur done.
Old Jul 22, 2004 | 03:08 PM
fborg's Avatar
I have no clue about that stuff so what sensor (how does it look like)???
Old Jul 22, 2004 | 03:13 PM
Iamkar33m's Avatar
sensor is like the size of a spark plug, it screws into the catalytic converter. U gotta unscrew it from there then screw it into the test pipe then bolt the testpipe back into where the stock cat was.
Old Jul 22, 2004 | 05:29 PM
TURBOit's Avatar
yea man, that should be easy, unless the bolts are rusted and you gotta jerk around a wrench while your car is sitting on just a jack, my advice, put 2 jacks stands under it and bricks behind the tires on the ground, then you should be straight
Old Jul 22, 2004 | 05:38 PM
camaro379ss's Avatar
best thing to use is a breaker bar, that is what i used and the o2 sensor came off like butter.
Old Jul 22, 2004 | 05:57 PM
BlackLancer2k2's Avatar
just make sure you take out the o2 sensor first, before takin out the cat.. it'll be very tough to do it when the cat is loose
Old Jul 22, 2004 | 06:07 PM
fborg's Avatar
What's a braker bar???? Damn the only thing I have is a Screwdriver lol! Don't you guys know someone in my area who will do that for a couple of bucks!
Old Jul 22, 2004 | 06:13 PM
yellance's Avatar
I live in irvine if you need some help pm
Old Jul 22, 2004 | 06:19 PM
Alchemist's Avatar
The b1tch of it is, you're probably gonna get sick of the ricey sound, nearly asphyxiating yourself at every stop light, and lack of torque after a few thousand miles, likeI did, and like a lot of folks I know. This is something you're REALLY gonna want to learn to do on your own.
Old Jul 22, 2004 | 06:21 PM
A breaker bar is a huge tool that amplifies your work in order to remove tough things easier than using a small wrench.
Old Jul 22, 2004 | 06:45 PM
fborg's Avatar
So did you remove it or do you still drive around with it?
Old Jul 22, 2004 | 06:46 PM
fborg's Avatar
I will pm you later! Thanks
Old Jul 22, 2004 | 07:20 PM
LancerEvoMR's Avatar
Moving to USLG.
Old Jul 22, 2004 | 09:21 PM
blacklancer03's Avatar
i got mine put in by the local street racer/tuning store. it looked like the bolts were pretty FREAKIN tight on mine..(brand new) took 3 of em. and a hammer haha
plus 2 of em burned the shiot outa their hands near the cat converter.
