BIG NOOBIE question
Old Aug 19, 2004 | 08:01 AM
illuminati's Avatar
BIG NOOBIE question
ok i always get confused and some asked me to explain this to them but again i got confused here is my question
front strut bar i know what it does
rear strust bar i know what it does
whats the difference between rear lower tie bar and rear lower pearches
and also for my curiousity is there anything we could do for our lancers for the front lower part and what would be the best way to approach this get everything or you dont need evrything and if i didnt mention parts that would help please add them on
thanks
i know there must be a search for all this things just hoping someone could just explain this all in one post instead of searching every item i think needed
thanks again
Old Aug 19, 2004 | 08:08 AM
gregivq's Avatar
Rear Lower Tie bar
Used to stiffen the chasis of your car.
Basicly when you turn your car will not look like it's going to roll over.
Rear Lower Perches are used to hold the rear sway bar.
Sway bar is used to connect one shock absorber with the other one.
Just transfers the inertia (force).
If you would have to buy an aftermarket sway bar you would have to
get better rear perches too, because our stock ones are not strong enough.
Sway bar is cool, but you don't need new perches if you are not going to
get an aftermarket sway bar.
Old Aug 19, 2004 | 08:11 AM
Danno's Avatar
https://www.evolutionm.net/forums/sh...1&page=2&pp=15
Go to post 25 (my post) and start from there. I had simular questions.
Hope That helps.
Old Aug 19, 2004 | 08:16 AM
illuminati's Avatar
so i could put the rear strut bar
rear sway bar and perches
and rear tie bar on my car at the same time
Old Aug 19, 2004 | 08:18 AM
Danno's Avatar
Yup...you might wanna stiffen up the front end a bit if you are going that far though.
Old Aug 19, 2004 | 08:39 AM
illuminati's Avatar
what can you put in the lower front part
Old Aug 19, 2004 | 10:33 AM
illuminati's Avatar
what are yoru opinions put everything
put the tie bar or just a sway bar and perches
Old Aug 19, 2004 | 10:38 AM
SIMSSEGA's Avatar
as far as i know there is no front tie bar or front sway bar
all you can do is put a front strut
Old Aug 19, 2004 | 10:58 AM
Myszkewicz's Avatar
I already have the lower rear tie bar, am getting the upper rear strut bar, and plan on getting the rear swaybar and perches. If that doesn't stiffen it up enough, then I'll look at new springs.
Old Aug 19, 2004 | 11:03 AM
lancermarin's Avatar
Which should be enough, unless you're involved in some serious rallycross.
One of the primary reasons to 'stiffen' the rear suspension is to eliminate the understeer both inherant and built-in to FWD cars. Under normal driving, understeer gives the car a more controlled feel, while a slight bit of oversteer feels like the rear wheels are tracking the front during a sharp turn.
I've never raced my li'l car and can't really elaborate more.. but there is a definite difference in handling 'feel' between my ride and the RWD Fords I drive at work.
Old Aug 19, 2004 | 11:06 AM
There was a fairly massive thread about Tein coilovers in which Hob and Brian imparted some serious spring knowledge. And I'll be damned if I can't find the link.. but it's around somewhere.
Yar.
Old Aug 19, 2004 | 11:07 AM
pgmike's Avatar
the springs may actually reduce oversteer
Old Aug 19, 2004 | 11:16 AM
Found it..
https://www.evolutionm.net/forums/sh...ad.php?t=90851
Good discussion on suspension tuning through coilovers after you've done all the bars/ties/etc.
