Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Quick help on taking flow metter out?
Old May 21, 2005 | 09:37 AM
MitsuLancerTO's Avatar
Hey all,
I'm trying to install an RMR intake and i'm following the steps...but at one point i need to take out the air flow meter from the air box. It mentions to use an impact gun, but don't have one available. Is there any way to take this out without using one of these guns?
i've kinda stripped one of the bolts...so i'm not sure what other option to do...
thanks for any help!!!
Old May 21, 2005 | 09:41 AM
12mnkys's Avatar
are you talking about the mass airflow meter???? If so you do NOT need an impact gun! There are four bolts and i think they are either 10mm or 12mm...all you need to use is a 1/4" drive ratchet...if you have stripped one of the bolts completely you may need to get ahold of a dremel and cut the head off...I will also stress the fact that on the inside of the MAF there is a screen that is extremely fragile...don not touch it with your hands or you will bend the vanes...
Mike
Old May 21, 2005 | 09:44 AM
hey...thanks for your help and advice...i used a socket wrench...but once i did it slowly..it broke the plastic that was sorrunding the metal head of the screw...i don't really want to cut it as i don't have a dremel drill...i'll try it again..but reeaalll slow..
EDIT: i did use a racket wrench..and that's what broke off the plastic sorroundings....it looks like the screws have some type of coating, almost like glue that make them bond together tight...
Old May 21, 2005 | 11:12 AM
12mnkys's Avatar
well good luck...i hope everything works out for you... you should get it no prob!!
Old May 21, 2005 | 03:46 PM
Kelspar's Avatar
i destroyed mine trying to swap intakes; ended up just junking stock setup completely
Old May 22, 2005 | 04:54 PM
rhyzin's Avatar
i was able to prop a 6" wrench on the inside of the box while loosening the nut on the outside.
Old May 22, 2005 | 05:44 PM
smokin_oz03's Avatar
i stripped the heck out of all of them, i just used pliers and alot of elbow grease, but i too trashed my factory intake. Managed to spare the MAF though!
Old May 23, 2005 | 08:53 PM
damm...that sucks to hear...i tried again to take it out, but was unable to..almost wrecked the MAF...but it's all good...
been speaking to a mitsu mechanic that holds these tuner days at the dealership and he's gonna try and help me out with it...
again..thanks a lot for all the advice you guys!
Old May 28, 2005 | 12:41 AM
arnold16890's Avatar
i installed my injen yesterday and ran into the exact same problem (read my other thread). i also trashed my stock air box, but the MAF wasnt even scratched~~
RSGuy
12
Oct 15, 2012 03:37 AM
jdm96gsr
Mar 8, 2011 10:14 AM
SpeedJunkyz
Northeast Region
Jun 23, 2008 07:02 AM
Thwack
For Sale - Miscellaneous Automotive
Sep 8, 2005 01:25 PM
