how to paint callipers....
Just get a can or 2 of caplier paint. Stuff the wheel wells with old newpaper to protect from over-spray. Use directions on the back of the can for best results. Also, heard others use high-temp clearcoat over the paint for a longer life. Good luck and do a good search for longer directions next time.
yep, there were 2 thread on the topic recently. Most people just pick up some caliper paint at auto parts stores, or get the duplicolor caliper paint and then just follow the instructions
i think with the duplicolor kit you dohn't have to worry about overspray cause it comes with a can of paint and brush (not spray paint like some other kits)
i'm a bit timid about painting mine, cause melaz here in CT told me his only lasted 6 months or so cause of the salt during winter time. if you live down south, i'm sure you'll be fine though, or try the clear coat idea
i painted my calipers with just the caliper spray paint from autozone and they came out great. just took the wheel off, took the caliper as far out of the wheel well as the brake line would come, lay a towel down to cover the whole wheel well, sand the caliper, clean it, then spray away in thin coats. let it sit overnight to dry. really easy.
Kasper
58
Feb 21, 2021 11:07 PM
alexis525
23
May 14, 2004 05:24 PM
