Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Request: Rotor removal
Old Mar 6, 2006 | 06:48 PM
sykou's Avatar
Question Request: Rotor removal
i need to replace my rotors up front. Does anyone know how to take them off and if possible, can it be done without an impact wrench? thanks
Old Mar 6, 2006 | 09:18 PM
comatose721's Avatar
i'm sure there is a thread on here somewhere with this info. here are the shop pic's though. air tools are not necessary. when i do brakes, i don't use air tools. i prefer a nice 1/2in socket wrench. the first shop pic if for removing stricly rotors. the other (w/red arrows inserted) shows the other 2 bolts you'd need to remove in order to change the pads. i'd recommend doing it all at the same time....sorry my writing isn't to informative(i'm having a rough night).....just follow the steps in order from 1 up. IF YOU ARE NOT COMFORTABLE WITH YOUR MECHANICAL SKILLS DO NOT DO BRAKES ALONE YOUR FIRST TIME!!! MAKE SURE A PERSON WITH EXPERIENCE HELPS YOU!!! i can't stress this enough. if you need written instructions and can't follow the diagram-->let me know. i'll do a write up with pics.
mark
Attached Thumbnails Request: Rotor removal-brakes0001.jpg   Request: Rotor removal-brakes0002.jpg
Old Mar 7, 2006 | 02:45 AM
sykou's Avatar
oh thanks a lot i think i understand it. gotta reach the two bolts holding the rotor on from the inside of the wheel area then huh. can i reach it with a torgue wrench? just wondering cus it seems like a small area...
Old Mar 7, 2006 | 01:10 PM
there isn't any real need for a torque wrench. a socket wrench will do you just fine. if you prefer a torque wrench, you'd be able to get it in there. the long handle makes it frustrating though. some people can fit an impact gun in there...mine is to large. it's really not a hard job to do though. good luck. PM me if you need anything else or have any questions.
Old Mar 7, 2006 | 01:25 PM
Maggatslayer's Avatar
Here is a step by step process for removing and installing new brake pads and rotors:
http://www.edmunds.com/ownership/how...7/article.html
Old Mar 7, 2006 | 02:30 PM
thanks for chiming in
Old Mar 7, 2006 | 04:16 PM
sykou's Avatar
thanks for the write up. It said something about cleaning the rotors with brakleen?? is this really necessary since im getting brand new rotors? if i need to do it, should i put the rotor on the hub then spray it with brakleen or spray it first and then put it on the hub?
Old Mar 7, 2006 | 06:49 PM
theres no reason to do that if the rotors are brand new. just make sure you wipe them off with a clean rag to ensure no grease or gunk is on them...that way you can ensure better braking and proper break in period.
Old Mar 7, 2006 | 09:48 PM
sykou's Avatar
oh okay...BTW no one has done a write up on changing rotors and pads yet right...i guess ill do one when i get them in.
grincon1995
Mar 31, 2017 07:25 AM
Jovan Caro
Feb 14, 2017 03:08 AM
lan_evo_mr9
17
May 9, 2006 09:59 PM
hypo74
Jun 16, 2005 11:28 AM
westchester evo
Mar 4, 2005 11:47 AM
