Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Idle screw bad or good? and Help!
Old Oct 30, 2006 | 11:33 AM
sdhes's Avatar
I've been reading old threads for three days and I am starting to get blurred vision, and I am no closer to knowing the answer. So I would like to know what the general consensus is regarding the idle adjustment screw on the throttlebody, and my idle problem.
Problem: A couple of months ago, right after I put the NSC damper on, my car started having idle problems. Specificly, when in park the engine would vibrate like it was going to die, then it would rev up, then start vibrating again like it was going to die, then rev up, and so on. It would vibrate even worse in drive (auto) and was made more noticable by the damper. I can feel it in the steering wheel and pedals.
Attempts to fix: I have done a number of things to fix this problem and this is a list of them:
  1. Checked for vaccum leaks
  2. Checked piggy V1 wires
  3. Got new plug wires
  4. Got new plugs
  5. Used Injector/fuel system cleaner
  6. Cleaned MAS/TB
  7. Installed new alternator/compressor belt (mechanic did)
  8. Installed new exhaust gasketts
  9. Reset ECU (several times)
  10. Checked grounds
  11. Changed PCV Valve..............and finaly
  12. Adjusted screw on TB (about 6 counter clockwise turns)
Adjusting the TB screw seems to have fixed(?) the problem. I have read that this is not good to do, and I have read that this is exactly what to do for my problems. So, which is it?
I am reserving judgment on wether or not this has fixed the problem until some time has passed and my idle problem has not returned, but for now it seems to have fixed it, if not made it alot less noticable.
Let me know what you think about my idle problem, what I did to fix it, and if you have any other suggestions, ideas, or opinions on the whole matter, they are welcome.
Old Oct 30, 2006 | 11:50 AM
crypto's Avatar
Former Vendor
i thought adjusting the screw just leans out the mixture a tiny bit.
it is supposed to be bad because it lets air in that the sensor is not picking up.
i did it but all it seemed to do was stall my car so i put it back to normal
Old Oct 30, 2006 | 12:16 PM
prench's Avatar
The only thing the biss screw does is opens the tb fractions of a mm to allow more air in for a slighly higher rpm idle, this air is still metered by the mas so the a/f stays the same
I even took pics for you, sorry for the crappy digi cam, its all I got
Old Oct 30, 2006 | 12:20 PM
prench's Avatar
crypto, what I think your talking about is the plug and screw on the mas, this is a way to get more air in, but you need an safc to offset the extra air. He was talking about the biss screw on his tb. just to clear things up!
Old Oct 30, 2006 | 12:24 PM
crypto's Avatar
Former Vendor
Sorry i got confused, i thought he was talking about that screw on the bottom of the MAF
<<<retarded
Old Oct 30, 2006 | 01:08 PM
Walkingchaos's Avatar
Id like to raise my resting idle by maybe 200rpm, is that screw i nthe picture the best way to do it ?
Old Oct 30, 2006 | 02:00 PM
prench's Avatar
yep, let the car idle, take a phillips screwdriver and keep turning the screw until your happy.
Phillip
Old Oct 30, 2006 | 02:08 PM
sdhes's Avatar
idle adjustment-idle-speed-adjust.jpg This is the screw I am talking about, not the one pench is.
Also another thing that I did before I started having problems was the coolant bypass for the TB.
Since I started this thread I have also cleaned the EGR valve on the drivers side of the intake manifold, at the bottom of the IM. Mine had a lot of carbon build-up in it. I just sprayed it with carb and choke cleaner, put it back on and I was able to close the TB screw some and idle somewhat smoother. I took it back off and am letting it soak over night to see if that fixes it.
I am getting my info from a thread that comatose talkes all about misfire and idle problems. that is where I got this pic as well.
This thread and others:
https://www.evolutionm.net/forums/sh...ght=Idle+screw
Basic's on Misfire
Jan 7, 2006, 02:06 PM #27
here is the message i sent to AVsparta. this should get some of you who are unfamiliar with misfire steered in the right direction to correct your own:
get a drink; this a long read. did you happen to pull the code from the CEL? that would really help diagnosing the problem although it went away. lots of times new problems spring off of the original one.
...but here's how it works in a nut shell. your engine works on compression. air and fuel mix and a spark ignites the two causing the piston to be forced back downwards, thus the crankshaft to spin. there are several other factors involved but that is the general concept you need to grasp.
alrighty now here is how misfire works. somewhere in that cycle there is a mishap. insufficent spark, poor fuel mixture, an inaccurate o2 reading, crappy air quality, poor vacuum, etc. are all things that can cause these little mishaps. this break in the cycle causes things to get a little funky. since one thing or another isn't working properly you will not be getting proper combustion....hence the loss of power during the misfire...
okay now we have an idea of how the motor works and one type of misfire
here are some things that you should check. start cheap and start simple.
- spark plugs: remove your plugs and make sure they are not burnt out, fouled, etc. if you do not know how to read a spark plug let me know. i have a nice site for you to check out then. look at all 4 plugs next to each other to identify which cylinder is misfiring. if needed, change and/or regap them.
- coil packs/plug wires: while the plugs are out check the coil packs and plug wires. inspect the insulation boot on the bottom of the shaft. look for signs of arcing. when your spark arcs it grounds itself to the cylinder wall (no good). signs of arcing usually include, but not limited too, a faint white or brown trail on the boot or pack. look closely for these. they dont just jump out at you. if you are unsure about arcing-->mail me pics of everything and ill give my two cents. the plug itself will be burnt around the base in more severe cases. if the insulator boot is 'bad' the pack may still be good. in most cases just the boot can be removed and replaced, held on by rtv silicone.
- PCV valve: ...positive pressure crankcase ventilation valve...its a long one and it sounds complicated...its simple. this is that silly gold,silver,or black threaded peice on top of your vavle cover (where that 3/8 vacuum line attached to the ONLY opening on top of the valve cover). go to your parts store and get a new one if it hasn't been replaced. they are between $3-6. it will improve fuel economy and help the motor function with less effort.
- air filter: it's simple. make sure it is clean and that it is free of debris. keep good, quality air in your engine.
- vacuum leaks: look under the hood for leaks in ANY of the vacuum lines. most vacuum lines branch from the intake manifold, throttle body, intake, and fuel rail. make sure that none of these lines are punctures, dry rotted, etc. lack of vacuum will cause misfire.
- EGR system: i believe it stands for 'exhaust gas recirculating system'...check it. make sure your EGR valve is not sticking open, or failing to open. while you check this, clean out any carbon build up on the butterfly within the throttle body. these are all problems usually associated with throttle lag and rpm hang but can contribute to misfire.
- oxygen sensor (o2): you already replaced yours so you shouldnt worry about this one. a bad o2 sensor will give inaccurate readings to your ECU. the ECU then tells the injectors to dump the wrong amount of fuel...misfire.
- fuel system: this is one of the more complicated sides of a misfire. check your fuel pump, fuel filter, and fuel lines. a bad pump, clogged filter or clogged line will starve the engine of fuel. if all of these are ok move onto the fuel lines under the hood (both feed and return lines). it is common to get a bad o-ring where the line bolts to the fuel rail causing a fuel leak (fuel pressure drops...yeah thats bad). it is likely that your fuel rail is fine so it's not a big deal if you don't pull that off. MOST IMPORTANTLY-->fuel injectors!!! a clogged, leaky, or defective injector will cause a problem. this is common. before you go replacing your injectors throw a can of injector cleaner in your tank of gas and see if that cleans the fuel system out. poke your head around for leaks and such. if there are no leaks you should be in good shape...but like i said, injector cleaner works miracles.
- timing: this is to complicated to explain...thus usually to hard to fix yourself. it is unlikely for the timing to just get "set off" in an 02 lancer unless you tampered with it in any way.
alrighty. that was a nice little read now wasn't it
...leave it as this-->if you are unsure of what you are doing when it comes to the fuel system...DO NOT DO IT. i dont want to find out you sprung a fuel leak and the car exploded on the freeway.
so to sum things up: start simple --> plugs, packs, air filter, PCV valve, and some injector cleaner. that is where the problem is 80% of the time. if it isnt in those things, then dive in deeper with the other things i mentioned. of course there is more to it than what i wrote but i am just trying to steer you in the right direction. let me know how things work out with the car. if you have any questions do not hesitate to ask me. i'm around here a lot. good luck. i hope to hear back from you soon.
Mark
Old Oct 31, 2006 | 06:54 PM
sdhes's Avatar
Anyone else? I would like to hear from some more people on this
Old Oct 31, 2006 | 07:45 PM
I found that my throttle body doesnt seem to have that scrwe, it has a bolt with a nut on it to do the adjustment. I just threaded the bolt in a little further and raised the idle about 200rpm.
Old Nov 1, 2006 | 02:40 AM
xspsi4's Avatar
was it the throttle stop you adjusted>
Old Nov 1, 2006 | 04:17 AM
sdhes's Avatar
It is this screw that I am talking about. I'm not sure what the technical name for it is but it lets more air in at idle
Old Nov 1, 2006 | 04:08 PM
sdhes's Avatar
Ok, forget it, thanks
Old Nov 1, 2006 | 09:35 PM
CoreyJBarron's Avatar
yeah where is that screw? my car has been idling bad after rrm pulley and intake were installed. oh and my o2 sensor is burnt that is probably the problem... autozone says $230 for a new o2 sensor, yeah right.
Old Nov 2, 2006 | 04:35 AM
sdhes's Avatar
For the third time:
Boy this thread turned into a useless, smoldering pile of crap!
Raceghost
32
Dec 9, 2020 01:19 PM
clanzkiller
25
Mar 15, 2017 09:55 PM
Raceghost
Jun 10, 2016 11:28 PM
89turbosupra
Oct 9, 2015 09:51 AM
