Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Request* DSM 1G Throttle Body Install
Old Dec 14, 2006 | 10:53 AM
krnzzang84720's Avatar
I really want to install this 63mm DSM 1G TB! can somebody please please do a write up on parts needed to install this parts!!
Old Dec 14, 2006 | 11:10 AM
phil_'s Avatar
The stock 1G TB is 60 mm, I'd recommend getting the NT TB model to eliminate the TB elbow used on the turbo models.
basically the TB bolts right up to the g93 manifold, however you need to get 2 more of the smaller TB bolts to replace the stcok longer bolts. To see to most gains from this mod you should bore out the TB flange on the IM to the size of your TB.
Now the main difference between you installing this TB, and me installing it is that I'm running a Megasquirt standalone ECU. This enables me to use any TPS, and to eliminate the IAC. The stock ecu should work fine, just make sure you get a 2g TPS to simplify wiring. Its also possible to use a 1G tps, you just need to wire in the "throttle closed switch". Refer to http://www.mirageforums.net/viewtopic.php?t=7105
I havn't experimented with the stock ecu with this mod. To splice in the DSM TPS
(2G) you need to make the following connections:
Stock harness 5vref(grey wire) > DSM TPS 5vref(Green/Yellow)
Stock Harness signal (green) > DSM TPS signal (Brown/Red)
Stock Harness ground (black) > DSM TPS ground(black)
If you are using the stock ecu you will have to figure out how to use the dsm IAC, I'm sure it's possible. The stock IAC has 2 power wires, 4 stepper motor wires. The dsm IAC has the same setup.
Old Dec 22, 2006 | 03:37 PM
Old Dec 23, 2006 | 08:38 AM
Iamkar33m's Avatar
That goes to the cruise control unit (left side of the engine bay near the washer fluid tank), the line is the cruise control vacuum which is to control the actuator that controls the butterfly when you have your CC on.
Old Dec 23, 2006 | 10:26 AM
phil_'s Avatar
with the dsm TB swap you cannot use the stock cc module.
Old Dec 23, 2006 | 11:15 AM
so can i just leave it; Opened or closed or what??
that don't cause no engine light??
Old Dec 23, 2006 | 01:27 PM
phil_'s Avatar
I just removed the CC module, aswell as the controller.
Old Dec 23, 2006 | 10:26 PM
hmm well what did you do with the vaccuum line??
Old Dec 23, 2006 | 11:02 PM
Iamkar33m's Avatar
Read bro... he removed the module (the actuator, a.k.a. the gold hat thing), and the controller (follow the vacuum line and you'll find the controller, should be on the left side of the engine bay near the washer fluid tank). If you remove the controller the vacuum line is attached to the controller and it will come out too. If you want to leave it in there then just leave the hose disconnected.
Old Dec 24, 2006 | 01:45 AM
sorry i am kinda noob ;D
Old Dec 24, 2006 | 09:42 AM
Iamkar33m's Avatar
Hmmm, I hope you have your hands on a Lancer Factory Service Manual if you're gonna do a turbokit without much knowledge of where stuff is.
Old Dec 24, 2006 | 12:10 PM
heh i do have manual with me ^^ also i have previousely installed RRM turbo kit before so i kind of know what i am doing but... i still need to know lots of thins, thx u
Old Jan 6, 2007 | 12:54 PM
hey guys i just installed DSM TB with 2g TPS Sensors and getting high idle (2K). can you help me plz..
Old Aug 22, 2007 | 09:22 AM
lancerrally45's Avatar
bump. how was it fixed
Old Dec 22, 2007 | 06:54 PM
Jehuty's Avatar
So, does this swap change the sound of the exhaust or does it sound the same?
