Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
changin the headlight bulbs
Old Apr 30, 2007 | 08:01 PM
johnd651's Avatar
ok so dont laugh at me...but something just dosent seem right
(yeah and my car never came with a manual either)
i wanted to change the headlight bulbs (9007) and was wondering what to do.
if anyone knows...let me know
like the drivers side is between the battery and the fender...and the plug is on good....im afraid of either ripping the plug or pulling the bulb through the plastic holding it in?!?!?!!?!?!?
on the passengers side theres that metal line (what is that by the way ...ac or power steering is my guess) anyway...theres a cable pluged into it and i cant get my hands around it...same thing....plugs on really good...and also the cable seems really tight ...like no slack...(i wont rip it ...has anyone experienced that yet)...and that plastic....like i feel like it might crack...
oh yeah and i know the plastic turns to come off...but i cant take the bulb out since the cables so short .... not enough slack
is it me....or is there a trick i missed?
Old Apr 30, 2007 | 08:07 PM
gomfears's Avatar
I have a 2002 OZ, when I changed my lights they were pretty difficult to get off to so I just used a pair of plyers to grip the hard plastic at the base of the bulb so I could pull it out.
Old Apr 30, 2007 | 08:19 PM
ThunderOZ's Avatar
??? it's pretty simple... I can't provide pics but I'll try to explain it...
1. There is a locking ring where the bulb goes into the housing...
2. Turn it to unlock it (lefty loosey)
3. pull it back slightly and turn the piece that holds the bulb.
4. Carefully pull the bulb out of housing.
5. Pull bulb out of bulb socket.
6. Replace bulb while being careful to not touch it with your bare fingers.
7. follow steps 4-1... you in reverse to put it back in there...
Old Apr 30, 2007 | 08:27 PM
johnd651's Avatar
yeah thats my problem though...the cables tight and wont let me pull the ring and bulb combo out as one...and wen i try pushin the tab and pullin the plug its really tight and doesnt wanna budge
Old Apr 30, 2007 | 08:29 PM
ThunderOZ's Avatar
unscrew the ring first... then turn the part that holds the bulb
Old Apr 30, 2007 | 08:33 PM
johnd651's Avatar
did that....but when i pull the bulb out of the headlight....like half of it stays inside the headlight and i got no more slack to move the bulb out further...it seems like i gotta unplug it first...
if i unplug the socket first....will the plastic ring crack....???
Old Apr 30, 2007 | 08:37 PM
ThunderOZ's Avatar
h/o im going to go and check mine and come back...
Old Apr 30, 2007 | 09:02 PM
ThunderOZ's Avatar
ok on mine it just pulled right out after i undid the locking ring... if you have no more slack try to pull some more of the wire up...
Old Apr 30, 2007 | 11:21 PM
johnd651's Avatar
ok....cool i got some slack on the drivers side....much easier
but the passenger side ....no budge....i just unplugged it while it was still in and luckily nothing happened...
by the way...what is the metal line on the passenger side (a/c?)
Old May 1, 2007 | 12:56 AM
ThunderOZ's Avatar
i think its for freon or something
Old May 1, 2007 | 08:13 AM
Newfoundlancer's Avatar
Don't worry about unplugging the bulb first... undo the lock ring, unplug the bulb, then just wiggle the bulb out. I find it easier to have the bulb unplugged first anyhow since there's a higher risk of touching the bulb itself if it's outside of the housing when trying to unplug it. Easy peasy
Old May 1, 2007 | 11:14 AM
johnd651's Avatar
thanks guys....i got them both changed....
one side i took the ring off and unplugged the bulb
other side i unplugged it first and then took the ring off
thanks for the help
Old May 1, 2007 | 05:49 PM
Good work! Now you know how to do it for any other time you need to do it. That's how the whole DIY thing works
Old May 2, 2007 | 12:41 PM
johnd651's Avatar
lol...thanks....by the time im done u guys are gonna be sick of me...lol
nekkidlad
Feb 21, 2013 01:37 PM
slowx
Feb 27, 2012 08:21 AM
kevin1986
Lancer Troubleshooting
Feb 4, 2010 04:52 PM
YogSaahoth
Mar 16, 2007 01:50 PM
wiretap
Aug 7, 2005 05:19 PM
