Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
exhuast question?
Old May 13, 2007 | 07:12 PM
johnd651's Avatar
exhuast question?
im thinking of upgrading my exhuast.....and was looking around.... found some stuff and was wondering what the deal is...
http://cgi.ebay.com/ebaymotors/OBX-E...QQcmdZViewItem
this is an exhuast manifold and pipe
http://cgi.ebay.com/ebaymotors/N1-CA...QQcmdZViewItem
this is a cat-back....
do i need anythin else in the system....
where did the catylitic converter disappear?
Old May 13, 2007 | 08:23 PM
stEVOx's Avatar
cat back looks nice, but its 2.5", isnt that a lil big for lancer
Old May 14, 2007 | 03:27 AM
Defcon5Es's Avatar
i got a greddy evo2 it sounds deep not ricey though.
Old May 14, 2007 | 03:11 PM
stEVOx's Avatar
^im looking for a Greddy evo2, but hard to find - esp. in aus.
coz i think it would be ok for NA, and great for when i goes turbo, true?
Old May 14, 2007 | 03:29 PM
SnapDragun's Avatar
2.5 is ok if your going turbo the headers and dp that u picked has been discussed here over and over. That header and dp will delete your cat converter thats why it has an 02 bung in it. as for that exhaust many people here have installed it and even put up vids of it at idle and revving.
Go through this thread https://www.evolutionm.net/forums/sh...d.php?t=252902 for the exhaust.
Go though this thread https://www.evolutionm.net/forums/sh...d.php?t=266581 for the Headers DP.
or this https://www.evolutionm.net/forums/sh...d.php?t=264862 for the headers and DP.
Old May 14, 2007 | 06:04 PM
Noe18's Avatar
i put a DC Sports cat system, i paid 500.00 and i love it, I also added headers from RRM, you cant go wrong
Old May 16, 2007 | 01:50 PM
johnd651's Avatar
ok....
but what im wondering now is.....what about the catalytic converter....wheres that in the whole system....is it part of it....or is this something extra i need to also get
Old May 16, 2007 | 02:07 PM
SnapDragun's Avatar
Did you not read my post thoroughly. If you get that setup (referring to the Header/DP combo) you wont have a catalytic converter because that system is setup not to use one.
Old May 16, 2007 | 02:32 PM
Noe18's Avatar
when you buy a cat system, you can used the stock catalytic converter, i just bought the test pipe
Old May 16, 2007 | 03:25 PM
johnd651's Avatar
i did....but what does an 02 bung do...
will it still be street legal w/o a cat
and....i thought it was cat-back....like after the cat converter?
Old May 16, 2007 | 03:29 PM
stEVOx's Avatar
o2 bung is for the o2 sensor, which is needed to read exhaust gases to alter the AFR
im pretty sure it wont pass emissions tests without the cat, not sure on US law
if u get a cat-back, yeah the exhaust is after the cat,
but i think NOE means when u get the Headers and DP u dont need the cat
Old May 16, 2007 | 03:35 PM
SnapDragun's Avatar
The exhaust system that u picked out is a cat-back system which means it is everything you need after the cat converter. The Header/DP system you picked is designed to bolt up directly to the catback system so which means that u will not be able to use a cat coverter.
2. Will it be street-legal? No removing any cat converter from your car voids the warranty and is illegal for street use. Our stock lancers have 2 of these cat converters - one in the stock header and one underneath.
3. but what does an 02 bung do? Our lancers have 2 O2 sensors on them that the ecu uses to monitor exhaust gases and adjust the A/F Ratio - one in the stock header and one in the stock cat converter. That since that header/DP combo is designed to remove both cat converters you still need to install the 2 O2 sensors in the system for the car to monitor the exhaust gases and adjust the A/F Ratio properly so the designer put 2 O2 bungs in the line so you can screw the stock sensors in - one in the header and one in the DP in the spot where the 2nd cat converter would sit.
Old May 16, 2007 | 03:46 PM
johnd651's Avatar
ok ... sweet....
yeah...im thinkin im only gonna go with the exhuast....not the headers...
ill take the car to a shop and have my headers fixed...(theres a small crack .... damn speed bumps)....
but now...with the exhuast i noticed it has a 3 bolt pattern.....does the stock catyltic converter have 3 bolt or 2 bolt?
its rainny and i havent had a chance to get out under the car yet
ManiakMik
Dec 24, 2006 01:03 PM
striderx88
Oct 26, 2006 03:48 AM
Walkingchaos
Lancer Aftermarket Forced Induction Tech
Oct 14, 2006 05:24 AM
Jokiesmurf
Oct 9, 2006 05:30 PM
zeus1
Sep 7, 2006 07:28 AM
