Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
cutting the headliner?
Old Jun 26, 2007 | 05:35 PM
johnd651's Avatar
hey everyone
i need to run a wire from my rearview mirror to my cigar plug...and i want to run it under the headliner except its really snug with the windshield....
i dont want it crushing the wire or cutting it...
anyone have any ideas on how to cut a piece of the headliner...or would it be better if i drilled thru it
anyone done this before?
Old Jun 27, 2007 | 10:21 AM
johnd651's Avatar
bump
anyone??? please help
Old Jun 27, 2007 | 12:03 PM
SLVROZ_03's Avatar
How about you take the necessary area off and route it that way.
Old Jun 27, 2007 | 01:37 PM
johnd651's Avatar
i did do that...only problem is that when i put everything back...my headliner crimps the power cable...and the last thing i need is
A) my electrical shorting
(and/or)
B) my undercover strobe being cut up
like the cable doesn't fit alone between the windshield and the headliner
Old Jun 27, 2007 | 01:42 PM
TSiAWD666's Avatar
Perhaps your headliner is different from my Evo's but I suspect not. I'm not sure why you're having problems with at least routing the wire along the edge of the headliner. I have what is essentially phone cord routing along the edge over to the driver's a-pillar where it then goes underneath and down to the fuse panel and it's not noticeable. I just pulled the edge of the headliner slightly and tucked the wire there.
Of course maybe I'm misunderstanding your issue or you're using a gauge of wire beyond what I would imagine up there.
Old Jun 27, 2007 | 01:54 PM
johnd651's Avatar
thats what i did...took off the trim on the pillar and the headliner...ran the cable in there...but the edge of the headliner is up tight against the windshield and i cant bend it back by hand...it is very rigid
Old Jun 27, 2007 | 02:19 PM
SLVROZ_03's Avatar
Well, I have never taken the headliner off...so good luck!
03upstatefire
Mar 27, 2015 08:28 AM
p1llar
Feb 7, 2013 05:02 PM
lanceritis
May 7, 2008 04:27 PM
spydervenm
Jul 20, 2005 05:13 PM
webguy330i
10
Dec 14, 2003 06:55 PM
