Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Taillight and headlight corner tinting!
Old Feb 10, 2009 | 07:57 PM
  #31
timo606's Avatar
Snopro did a real good job on his lights but I dont want to have permanent tinted lights. Is this http://cgi.ebay.com/ebaymotors/ws/eB...8661&viewitem= any good?
Old Feb 10, 2009 | 10:12 PM
  #32
I Am God's Avatar
eh, i would ge those becasue of the easy install but that 20% dark smoke aint even dark..i got a set of dark smoke from headlightarmor. and it straight looked black from a distance..but it was precut and it was the thick stuff 17-20mm no tint shop would install it for me for legal reasons so i went for it myself..turned out like ****..real hard to do, didnt cover the whole light. and was about 3 times the price of these..if ur not lookin to get tickets but still have tinted tails that u can install yourself with ease id say go for it..good price!
Old Mar 22, 2009 | 01:40 AM
  #33
momokoo's Avatar
cool... does it takes a long time to tinit...??
Old Jun 3, 2009 | 02:41 PM
  #34
09LAN's Avatar
looks good ... nice work on the splitter
Old Sep 17, 2009 | 11:25 PM
  #35
lancerarmstrong's Avatar
the lancer tail lights have embossed writing from the factory on them so film does look bubbled around that area on the lights if you use that. it's best to take your tail lights out and take them to go get tinted with a light coat of black+clear. looks sexy that way
Old Dec 4, 2009 | 10:51 PM
  #36
Dan the Man 18's Avatar
Question
Originally Posted by Snopro
i just recently tinted my taillights and headlight coners with this product called Nightshades spray on tint translucent paint...
Step 1: remove two philipshead screws and 10mm nuts holding the outer and inner lighting units and unplug sockets as neccesary...(lights are held in fairly snug and need some wiggling to take off)
Step 2: clean the surface with windex or a good glass cleaner and 70% alcohal solution works good getting grease or sutt off the lens
Step 3: Take the NightShades paint and spray 10-12 inches away untill a light shade appears, let dry and shake can vigorously for one minute then re-apply, this time, apply a rather noticable coat.
Step 4: Apply up to 4 coats for maximum shade and let dry for 1 hour ( preferably in the sunlight in temps of 70 degrees or more)
Step 5: re-assemble lighting units and test for currect coating and visability ( re-coat if needed)
Step 6: Enjoy your sportier lookin ride
headlight corners: tape off selected area and apply these steps but make sure to newspaper these areas!
First off, nicely done. Looks great man.
I'm trying to get the 1/2 of the tail light that's actually on the trunk off. Do I pop off the little rubber pieces holding the paneling in and get to it form under there?
Old Feb 16, 2010 | 04:50 PM
  #37
mishins's Avatar
After you get the 2 bolts unscrewd and twist and unclip the bulbs, you gotta use a bit of some muscle to just push it out of there from underneath. I used my thumbs to push it through and it popped off. Start with the bigger one, then the smaller one.
Old Feb 28, 2010 | 03:16 AM
  #38
AtThisVelocity's Avatar
Yeah, using film is the worst, It's easier on the third brake light cause it's flat, and the reflectors are flat too, but if you use film on the reflector, they still turn red when headlights hit them. If your going to tint any lights, i suggest using nightshades. just wet sand a little, clean em real good, and then light coats of night shade, and then clear coat. you can even put em under a heat lamp to bake the coats on.
Here's my set up. Nightshade+clearcoat tails and film on everything else.
Old Feb 28, 2010 | 03:32 AM
  #39
Domolution's Avatar
Not my cup of tea. \:
Old Jul 13, 2010 | 03:23 PM
  #40
biggiesmalls3's Avatar
Anyone with the tined headlights or tailights get pulled over ?Just in general was wondering if the cops really get on you or what ha .
Old Jul 13, 2010 | 08:22 PM
  #41
No, I never get pulled over, and I live in a somewhat bad area where cops pull you over for everything. Our tail lights are pretty big and pretty bright, so even with the tint on they still show. I dont think they really pay attention to whats going on outside the car, more about whats going on inside. If you get pulled over for speeding they might slap that on you too just to be dicks, but thats a real dick move.
I also have my front windows tinted to 20% and never get pulled over.
Old Jul 14, 2010 | 10:36 PM
  #42
Mc-Roux's Avatar
I want to get my rear reflector and third brake light tinted. But I don't know if I will go for nightshade of get them tinted with a film.
Also how do you remove the side marker in front of the door? I want to get those tinted. I don't like to have white/chrome thing on the outside of my car.
Did someone tried that http://www.flyeyeskit.co.uk/ I may try it to do what I just said for 22 buck it may worth it.
Old Jul 15, 2010 | 03:33 AM
  #43
kalpakiotis's Avatar
for side light, push in and towards the back of the car and it should pop out.
Old Jul 15, 2010 | 06:29 PM
  #44
If you look at the picture above I used film for my reflectors and third brake light, I would say use film for those because they are flat and the reflectors are hard to get out in order to paint. But since they are flat the film works just fine, plus it wont fade as fast as nightshades will. just use a heat gun in the area's where there is print on the plastic and it will form better. You can get pre-cut film on ebay for those too.
Old Jan 23, 2013 | 11:51 AM
  #45
ShiosX's Avatar
i might have to try nightshade, as of right now i have vinyls
Graphic
Jul 23, 2015 11:18 PM
digdat
Jun 25, 2014 07:58 PM
MA70Snowman
Sep 22, 2011 10:43 AM
tcon89
Aug 27, 2011 03:35 PM
Evoryder
Mar 5, 2006 07:42 PM
