Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How To: HID Install w/ Harness
Old Apr 4, 2008 | 04:41 AM
Lancer_GTS's Avatar
Originally Posted by mgeneral
I cant decide what temperature to get, I'm thinking either 6000K or 8000K. What do cars like BMW's use? Do the Evo X's have HID's, i thought I read somewhere that they do? If so what temp?
Pretty sure they have somewhere around 4300k
Old Apr 4, 2008 | 09:44 AM
elpoole's Avatar
im installing 6K for lows and fogs... Il post some pics when done.
8k will look after market - but nice. Im going with 6k cause they are brighter and have that crystal bright white.
Old Apr 6, 2008 | 01:59 AM
01_Tundra's Avatar
Great diy just installed my exes 5800k hid.
Old Apr 8, 2008 | 10:04 PM
AhFuJai's Avatar
can u still use your foglight??
Old Apr 9, 2008 | 05:53 PM
GeeTeeEss's Avatar
Anything over 5000k and you do sacrafice light output. I would personally go with 5000 for both fogs and headlights, or 5000 for fogs and 4300 for headlights.
Most stock vehicles have 4300k
The only other problem with HID fogs is when you flash, the highbeams come on (headlights stay on, no problem there..) but the fogs turn off...not healthy for HID... Is there a way to have the fogs stay on when flasing?
Old Apr 9, 2008 | 06:11 PM
kalpakiotis's Avatar
technically ur not suppose to flash people...ur suppose to flick off ur lights and turn them back on lol...i have a friend that got a ticket for flashing a cop that didnt have his lights on lol
Old Apr 9, 2008 | 06:15 PM
elpoole's Avatar
I got the **** installed and it looks perfect. Clear White yet still stock looking. Im uploading pics now.
Old Apr 9, 2008 | 06:29 PM
AhFuJai's Avatar
can u guys still use ur foglight???? using this method
Old Apr 9, 2008 | 06:41 PM
Old Apr 9, 2008 | 09:09 PM
AhFuJai's Avatar
elpoole really nice ur hids... =D are they 6000k or 8000k/?
Old Apr 9, 2008 | 09:37 PM
GeeTeeEss's Avatar
Correct about the flashing.. However now with HIDs you cant even do that. Unless you retrofit some bi-xenon projectors.
I flash people like this lol. Gross glare that blinds other drivers. I am only converting my fogs to 5000k until projectors are made or I have time to retrofit.
Old Apr 9, 2008 | 09:38 PM
nunyas's Avatar
you should be able to. You just need to make sure you have the turned all the way to the normal headlights on position...
Old Apr 10, 2008 | 04:04 AM
elpoole's Avatar
They are 6000k. In the pictures its hard to tell but the focus on the stock assembly is pretty good. I should have taken a shot pointing at wall so you can see the beam pattern. Is very horizontal with a defined cutoff. They are not projectors but its so close to call if they are stock or not; unless you know the car.
Old Apr 14, 2008 | 01:00 PM
TheDecoy's Avatar
My HIDs stobe when turned on
hey i have hids and whenever i turn them on they strobe. i took out the daytime running fuse to see if that fixed the problem but it didnt i am alittle confused on why they r doing that. plz help.
Old Apr 14, 2008 | 03:05 PM
Blacksheepdj's Avatar
There is no "daytime running light fuse" - while the manual calls it that, the DRLs are run through the ECM and cannot be deactivated. So your HIDs are getting DRL-level voltage, causing the strobing. You need to rewire your system if you want the HIDs to work.
Honestly, we've been talking about this for a year. You really should have read a little and you would have found it....
