Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How to: 04-06 bumper removal
Old Feb 6, 2008 | 06:04 AM
Juan Martinez's Avatar
I just swaped out my chrome headlights for a set of OZ/Ra black headlights on my 04 ES. I took some pics and decided to do a write up. I don't believe there is one on here for the 04-06. To take off the bumper, remove old headlights and put the new ones on only took about 30-40 min tops. I got off work at 4pm, drove 5 min home, got ready, and by 4:45, it was done. I would like to give credit for evom member livelyjay. I based my write up off of his write for an 02-03 lancer.
Tools needed
10mm socket
12mm socket
Socket Wrench
Flat head screwdriver
Phillips head/star head screwdriver
pliers, pointy tip if possible.
First step is to remove the plastic tabs from the front bumper. I included some extra steps for the radiator bracket because I have one of those heat shield panel things on there which had to be removed. Otherwise, you don't have to remove the radiator bracket. There should be 8 plastic tabs to remove. Behind the vents are some bolts you will need to take off with a 10mm socket or phillips head screwdriver.
Next, use a phillips head screwdriver to take out the screws to the fender well liner. There should be 2 screws. You may have to turn the wheel to get good access to them. Above the 2 screws is a bolt. Use a 10mm socket to get it out.
You should be able to pull down on the bumper and it will start to come off. Go to the other side and repeat.
Next, under the car, you will find two retainers. Use a pair of pliers to pinch them and remove them. I don't have any pics of under the car, but here is a pic of livelyjay s write up on his 02-03 bumper removal
If you are removing you headlights, make sure you unplug the 3 connectors behind the headlight before you take it out. There are 3 bolts. Use a 10mm socket wrench to take them off. The headlight does have a prong that pops out when you pull the headlight out. Don't worry what that sound was.
My finished product.
The bumper at these point should come right off. Reverse order to put everything back together. If I missed a step, please let me know. For the legal part, I am not responsible for any damages done to your car for attempting this. I hope thise helps out everybody who wants to change out their headlights or want to remove their front bumper. If an administrator wants to make this a sticky, that would be awesome.
Old Apr 13, 2008 | 02:39 PM
slatermvp's Avatar
this is mad easy to do it took me like 40 minutes to do. way easier to do than I thought.
Old Apr 20, 2008 | 09:02 PM
arnold16890's Avatar
nice, did you paint them or replace them?
Old May 1, 2008 | 10:19 PM
Momak's Avatar
sweet. that was pretty useful info. thanks!
Old May 7, 2008 | 12:23 AM
I replaced the lights with stock oz or ralliart ones.
Old Oct 2, 2008 | 08:16 PM
dhiq85's Avatar
is the crash/reinforcement bar bolted or welded onto the car....
Old Oct 4, 2008 | 05:51 PM
lancer2show's Avatar
the crash bar is bolted by 3 12mm bolts on each side if i remember.
Old Oct 28, 2011 | 06:07 PM
Cards77's Avatar
In prying out these plastic push-ins and retainers, can you put them back in or did you get new ones to push in when putting the bumper back on? Thanks.
Old May 19, 2013 | 09:51 PM
mrskoodle's Avatar
I also did replace my chrome headlights for ralliart ones (darker). Wish I had read this earlier. I did not fully take the bumper as I did not notice there were retainers under the bumper. Had the hardest time pulling out. Instead I just loosened the bumper and had an extra person to pull out the headlights. I broke many plastic retainers... can I get them from the store?
Old Feb 5, 2014 | 11:15 AM
jellotroz's Avatar
Sorry to bump an old thread but does anyone know if an 02-03 lancer front bumper will fit an 04 lancer ralliart? thank you in advance and sorry if this has already been answered I couldnt find any such thread.
Old Jul 11, 2015 | 04:13 PM
JTHunts's Avatar
Thank you! This was really helpful.
Old Jun 1, 2017 | 10:09 AM
schotzy49's Avatar
Awesome! thanks for the info!!
tlcoll1
Feb 24, 2018 10:06 AM
Evoryder
90
Jun 22, 2017 03:26 AM
mksevo
Evo X How Tos / Installations
18
Jul 19, 2016 03:38 PM
Mr. Evo IX
May 24, 2016 09:21 PM
arnold16890
62
Apr 18, 2016 01:48 PM
