Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How To: DRL's and HID's
Old Jun 27, 2009 | 08:46 AM
  #121
ae37's Avatar
Guys i finally did it. I made a relay harness and it works great. if anyone needs one, let me know, Im going to make and sell them for 50 dollars.
Old Jun 27, 2009 | 08:54 AM
  #122
1320 Engineering's Avatar
We offer the DRL relay for $25 shipped
PM me for more info
Old Jun 27, 2009 | 11:38 PM
  #123
ae37's Avatar
PM me for more info
Does yours supply direct power to the hids? are the hids off in position 1, or does your relay just stop it from flickering in position 1?
Old Jul 1, 2009 | 04:48 PM
  #124
skatedogg008's Avatar
I have an 08 GTS and have read all the forums about the HID flicker. I originally chose option 3, but it failed. Then, I decided to go with 1, even though headlights would always be on. My capacitor is 2200 uF and 35 V. When I installed and tested this I was happily surprised to see that after about 55 seconds, my headlights shut off, leaving my parking lights. Headlights then, come right back on. I would upload pics but it is not working. The other thing is, for some reason my relay looks different.
Old Jul 22, 2009 | 05:10 PM
  #125
i786533's Avatar
Question about option #1... using the extra 9006 extension cable...
seems to be missing a pic... but what does "in parallel" mean...
could some one please describe in more detail how to do this...
thank you
Old Mar 17, 2010 | 11:41 PM
  #126
shared's Avatar
http://en.wikipedia.org/wiki/Series_...allel_circuits
your basic physics.
Old Mar 18, 2010 | 10:34 AM
  #127
shared's Avatar
the diagram worked wonderfully.
if anyone is interested, i will be selling one relay harness shortly, as i have extra parts to finish another harness for someone else.
i will take pictures so you guys can see my soldering work if any of you are interested in buying the harness.
Old Mar 26, 2010 | 10:49 AM
  #128
shared's Avatar
Here are some pictures of my soldering work + harnesses if anyone is interested. My harnesses are different than that of JROX because my harnesses are removable for any 9005/6 application if you decide to change cars because the DRL bypass module is not soldered directly onto the harness, rather there is a separate harness that connects between the relay harness itself and the factory harness.
Let me know what you guys think!
Old Mar 26, 2010 | 01:08 PM
  #129
OZR_Lancer's Avatar
that looks clean
Old Mar 27, 2010 | 12:08 AM
  #130
shared's Avatar
thanks! appreciate it
Old May 13, 2010 | 04:51 PM
  #131
erikerwin's Avatar
will I get any problems from mitsu about wty issues if I install these. anyone know where i can get cheap projectors?
Old May 14, 2010 | 09:14 AM
  #132
shared's Avatar
you shouldn't get any warranty issues if you buy/use something like my plug and play harness as you can just remove the harness with no trace of it ever being there.
good place to get cheap projectors? multiple website. check retrofit source's website out and try hidplanet's store.
Old May 14, 2010 | 09:39 AM
  #133
erikerwin's Avatar
what projectors are compatible with our lancers?
Old Jun 8, 2010 | 11:44 PM
  #134
itsPJ's Avatar
I bought my HID kit and relay harness from ddmtuning.com
My lights flickered since my 2006 Lancer ES has DRLs and there was no way of disabling them. The relay harness itself didn't work so I bought the capacitor mentioned in this thread. From there, it worked perfectly. Great thread! Could have been explained a little more for those who have never installed lights but overall, great job!
Old Nov 7, 2010 | 03:05 PM
  #135
trickytrick's Avatar
I'm guessing that you need a harness relay as well for this to work
