Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How To: DRL's and HID's
Old Mar 30, 2009 | 05:13 PM
  #106
Hammerfeind's Avatar
Update:
Made a relay harness for it and it does the same thing, It just flickers with the headlights switch in the on position. Any suggestions.
I'm about to just say heck with it and use the parking light
Old Mar 30, 2009 | 06:36 PM
  #107
jRox's Avatar
You can always just go with the option of wiring a switch that controls the low beam headlights.
Old Jun 4, 2009 | 07:48 AM
  #108
ae37's Avatar
okay, so does option one work as described?
anyways, Im looking at buying this kit, but im not sure if it has everything I need in it that I will need... afeudale says it needs to come with a relay and harnesses... my kit comes with the ballasts and bulbs, what relay are we talking about now? and what is the harness? im so lost. I put the capacitor on the relay in the fuse box, right? Sorry for the newb Qs but Im trying to do this and im hesitant. anyways, heres the kit im looking at... does it have everything I need? thx a lot guys.
http://www.ddmtuning.com/index.php?p...=103&parent=85
ps... I know the picture shows a lot of stuff, but i think its strictly the ballasts and bulbs that come with it, right?
Old Jun 4, 2009 | 01:09 PM
  #109
fusionchicken's Avatar
i can't find much information on this regarding the Evo X...does anybody know if this method also works for the non-HID evo Xs???
Old Jun 4, 2009 | 10:28 PM
  #110
jRox's Avatar
^If you have the non-HID headlights (NO projectors) it should work. Check out my sig.
Old Jun 5, 2009 | 09:20 PM
  #111
ae37's Avatar
do any of you guys use 55 watt HIDS? any problems with them melting the harness/ housing?
Old Jun 7, 2009 | 02:23 PM
  #112
jRox's Avatar
I've been running 55w HID's since December. Haven't caused any problem.
Old Jun 11, 2009 | 04:43 PM
  #113
i786533's Avatar
Question about option #1... using the extra 9006 extension cable...
seems to be missing a pic... but what does "in parallel" mean...
could some one please describe in more detail how to do this...
thank you
Old Jun 12, 2009 | 04:20 AM
  #114
kalpakiotis's Avatar
It doesn't look like there is a relay with this kit, not sure why they have that smaller black box between the ballast and bulb, it could possibly be a flicker eliminator. Best to call the company and ask
Old Jun 12, 2009 | 03:04 PM
  #115
https://www.evolutionm.net/forums/ev...rls-works.html
here is a simpler way IMO, you power the headlights with the parking lights and take out the headlight relay. this will work on any Mitsubishi without factory HIDs. the guy that taught that method to me did it to his lancer as well.
Old Jun 13, 2009 | 10:42 AM
  #116
ae37's Avatar
for option 3, what should the power rating on the two resistors be? thanks
Old Jun 14, 2009 | 08:18 PM
  #117
ae37's Avatar
bump. please guys, do any of you know the power rating for each of the two resistors? 28kohm and 5kohm, should they be 125mW or 400mW etc... thanks.
Old Jun 14, 2009 | 08:28 PM
  #118
ae37's Avatar
also, how many volts for each? thx
Old Jun 15, 2009 | 10:02 PM
  #119
ae37's Avatar
noones ever built this harness? come on guys please...
Old Jun 16, 2009 | 01:00 PM
  #120
ae37's Avatar
perfect. thanks guys, youre the best, really.
