Help On How To Install Fidanza Adjustable Camgear
Set @ TDC
Loosen the belt tensioner
Pull off the belt
Remove the cam gear bolt
Remove the gear and replace with the new one
Replace the bolt, but don't fully tighten
Put on the T-belt
Tighten the belt tensioner
Make sure you're still @ TDC
Fully tighten up the gear bolt
Pull off the belt
Put on the T-belt
pinOyZ there alot of people here that has some experience on tunning etc etc but some are scared of messing with timing, i've got a adjustable cam gear but im not going to install it cause if i mess that up im a$$ out.
NocturnalEVO
Apr 4, 2006 12:26 PM
