How does one change the pollen/cabin filter?
I'm in the process of finding an alternate filter for this part. For anyone that might want to try and look it up and may have more knowledge here are the dimensions of the 08 lancer cabin air filter.
L 8 1/2 in. 216mm
w 7 7/8 in 200mm
h 1 3/16 30mm
So far my research has not found any cabin air filter with those dimensions.
L 8 1/2 in. 216mm
w 7 7/8 in 200mm
h 1 3/16 30mm
L 8 1/2 in. 216mm
w 7 7/8 in 200mm
h 1 3/16 30mm
L 8 1/2 in. 216mm
w 7 7/8 in 200mm
h 1 3/16 30mm
Right now i'm checking on the dimensions of cabin filters for cars like accord or other mitsubishi/honda cars that have a filter with the same dimensions
the nissan altima 02-06 has a filter that is close in size as well as a 2003 Honda accord, only problem is the length and width are switched with the length of our filters. I wonder if you could modify the filter any?
http://filtermaster.com/mu2se2ma2al2.html
I've been going through this site looking at all makes of cars to see if one of them is really close to same size. But still i get ones that are shorter in Length and wider than ours, height is the same though on some.
Like the 2003 accord cabin filter i wonder if you could just cut off a bit of it so it fits in our lancer http://filtermaster.com/accord2003.html
The filter of the altima should fit (based on your measurements). There is no need to modify the filter just because the length and the width are switched. Actually it depends which you called width and which you called length or if they're really switched then the crests will be horizontal instead of vertical and that is not a problem the filter will do it's job anyway.
haha anyone want to be the guineapig? Heck the infinity is a closer match again length and width are switched but like you said if you can just turn it then cool. http://filtermaster.com/fx2fx2g352.html
When i measured it I measured length from longest side (side with the part number) and width is the side without the barrier on the sides. Don't know if thats right but I do know the numbers are exact for the measurements.
so the filter got rescheduled in its delivery, so now i wont have it till the 21st...this may be like the first time i've waited more than 5 days for a package from anywhere...this sort of stuff usually comes in 2 or 3. I'll post back after its in and installed.
Yeah, if you ordered from Mitsubishiparts.net, you're stuck with DHL. WORST shipping company known to man. I never even checked on my filters (finally came yesterday), I just ignored it until they actually showed up.
no we didn't get it from there, were looking into the filters that are in the links in one of the posts above. Filterworks.com I think it is. And just for those who haven't read above these filters are not actual filters for the 08 lancer, they are filters for other makes of cars that have the same dimensions for the cabin air filter and are a hell of a lot cheaper. He got one of them to test it and if all goes well we can get a cabin air filter for like $15.
dealer anymore!
