switch for unused slots?
i have a 2009 lancer gts
there are 3 slots on the left of the steering wheel, which i assume is for switches.
now my questions is there a switch that will fit exactily into the empty space, and if so where can i buy such switches.
if there isnt any thing that would fit exactily into it. what type of switch can i use and fit in there. i am looking for a clean look, something that can be installed and look good, look oem. example of a bad look a white light switch that is secured with scotch tape.....
MOST switches come connected to or as part of a box that has a sort of friction based mount to them. Cut the hole the size you need and the flaring on the sides of the box generally catch the inside of the hole so it doesn't come out.
my guess is that those three slots were intended to have switches for other options for the car. i dont think
would cut a little hole into the slot to fit a switch... so where can i get those same size switches. do they even exist...does anybody have a switch in one of the three slots?? what is it for.
but would be there any that would fit nice and cleanily into one of those those three slots?
i want these switches so i can hook-up some internal LEDs that i plan to buy from Cut@MrLed...
also another for
the holes are cutouts for the EVO...not sure if the ralliart uses them. If you want the actual switches for it, im sure u can pay a nominal fee to
to get them, then u can hack them up and use it for what u want.
AlexC330NY
Lancer Troubleshooting
Mar 29, 2016 08:36 AM
Prodigal
Jul 15, 2008 04:12 AM
