Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
RRM Lower Tie Bar Set Install...?
Old Apr 2, 2009 | 12:23 PM
JoeyBallGame's Avatar
Can anyone direct me to the location that describes the installation of RRM's Lower Tie Bar Set Install...?
God Bless America
Old Apr 2, 2009 | 06:11 PM
I Am God's Avatar
it should be pretty straight forward i dont think a video is necessary...hit up rrm and ask em
Old Apr 3, 2009 | 08:24 AM
LWR Tie Bars Install...
I was waiting for Rock at RRM to notice my entry... I wouldn't of created the thread if it was already brought up in the blog... (am I using the word "Blog" correctly...?) My thoughts are, the more information I have about a aftermarket part the better. Plus, I'm getting close to the day I install the pile of parts I have in my dining room...
Thanks
JBG
Old Apr 3, 2009 | 01:43 PM
mattchan99's Avatar
Its actually quite simple. You can physically see the 2 flat piece bars that hold your rear control arm to the chassis. The torque rating you should use is around 10-15 lb ft. it should take only 5 mins to install.
step 1. raise rear end of car.
step 2. unscrew the 4 bolts holding the bars.
step 3. screw back in the bolts with the new RRM tie bars.
and you're done. The bars can only fit one way. It basically sits flush to the points of connection.
*IMPORTANT NOTE* YOU NEED 3IN SOCKET SETS IN LENGTH. in order to screw in RRM rods. your standard 1 inch length socket set will not do.
As for the front, its the same procedure
step 1. raise front end of car.
step 2. unscrew the 4 bolts holding the plate.
step 3. screw back in the bolts with the new RRM front strut bar.
As use 10-15 lb ft as a torque limit.
Old Apr 3, 2009 | 03:17 PM
WhiteGTS18's Avatar
yeah they have to be the easiest parts ever to put on. i just put my car on ramps and bam 10 minutes later the parts were on. i wouldn't really worry about torque either if you don't have a torque wrench, just dont go crazy on em.
Old Apr 4, 2009 | 03:45 AM
LWR Tie Bars and LWR Truss
Let me get this straight, the lower tie bars are for the rear stability and the lower truss bar is for the front...? Or are they both for the rear, or visa-versa...
Please tell me where they get installed...? I know that they are to stiffen the rigidity of the suspension geometry to give better response & performance. Especially in combination with the front & rear upper strut bars and the upgraded rear sway bar… Works in unison, I get it…
BTW - I haven't even looked under the car to even guess where they are installed... I don't have ramps, my uncle is letting me use his auto shop.
Old Apr 4, 2009 | 03:59 AM
I Am God's Avatar
1 sec ill get ya a pic
Old Apr 4, 2009 | 04:03 AM
I Am God's Avatar
pic 1 is self explanatory..pic 2...the cover circled in yellow is removed and the green is where the truss bolts up... its in the front right after the headers and cat..
Attached Thumbnails RRM Lower Tie Bar Set Install...?-1.jpg   RRM Lower Tie Bar Set Install...?-2.jpg
Old Apr 4, 2009 | 05:27 AM
Thanks for the help... One more ???
Thank you very much for the help... Do you also have pictures of the rear lower tie bars installed, at least on one side...?
Old Apr 4, 2009 | 05:52 AM
I Am God's Avatar
this is the best i can come up with..theyre products form an australian company http://ultraracingaustralia.com/page16.htm they offer a couple parts rrm doesnt...4 lower tie bars instead of 2, im not sure which of those in the picture are the ones rrm offers...
also a "rear lower bar"
Old Apr 4, 2009 | 07:14 AM
Thank you for your help...
Old Apr 4, 2009 | 07:29 AM
I Am God's Avatar
np, nuttin better to do at 5 in the morn
Old Apr 4, 2009 | 10:39 AM
smoke's Avatar
does our cars come stock with those bars? havent checked
Old Apr 4, 2009 | 12:25 PM
Stock 08 CVT ES Lancer...?
No, not stock... If your interested in the parts we are discussing or you see in my signature, go to http://www.roadracemotorsports.com/s...c223dd7675006d
That's where I've got most of my parts from... I trust'em...
God Bless America
Old Apr 4, 2009 | 12:38 PM
smoke's Avatar
one of the products RRM says "replaces the cheesy OEM bars" ....so i thought we had some
