Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Oxygen sensor replacement recommendations
Old Dec 8, 2010 | 12:34 AM
Beluga's Avatar
My check engine light is on and it's due upstream oxygen sensor. Any recommendation on which brand and model to use other than the oem as they are 350 in my local dealership while online they range from 50-150.
I am also looking for direct fit, I think Denso 234-4739 might be a good one but not sure. Would you recommend bosch or walker over denso.
Anybody know what kind is the oem?
Old Dec 8, 2010 | 05:21 AM
Mitsu.kid.02's Avatar
OEM is Bosch im pretty sure, i got a direct fit replacement at advanced auto parts for 98.00 it was also bosch, and havnt had a problem, check advanced auto to see if they carry direct fit replacements for your evo, i have a lancer oz so the 02 sensor may or may not be different
Old Dec 11, 2010 | 08:47 AM
fe2o3's Avatar
rockauto.com has Bosch direct fit for around 60-70 IIRC. Work fine.
Old Dec 11, 2010 | 06:35 PM
jsdragonsoul333's Avatar
rockauto is awesome. Used them many times for parts.
Old Dec 14, 2010 | 06:14 AM
fe2o3's Avatar
Actually I just remembered I have the Denso 234-4739 on the front and the Bosch direct fit downstream. Both from rockauto.com and both working fine so far.
Old Dec 25, 2010 | 10:20 AM
sioux90's Avatar
Used Bosch 15730.
http://www.amazon.com/Bosch-15730-Ox.../dp/B000BZL08A
It is not direct-fit, but it takes maybe 15 minutes with very basic understanding of connecting wires. Car runs probably three times quieter. Definitely worth $40.
Old Dec 30, 2010 | 10:35 AM
norcalrep707's Avatar
Bosch is a good brand...i would go with a direct fit replacement($63) just because its easier, less hassle and only five bucks more. The universal ($58)will take about an extra 20 min to install. You can pick up either of these at your local O'Reilly store.
Old Jan 10, 2011 | 01:58 AM
gohdunlam's Avatar
is the bosch long enough for the front? also it is longer then the original one cause i'm running an invidia o2 housing
thanks
Old Feb 4, 2011 | 06:38 PM
gohdunlam's Avatar
bought that 15514...its short as **** -_-
Old Mar 2, 2011 | 04:24 PM
is the 15514 the OE style or universal?
pilchenstein
31
Jul 31, 2022 03:33 PM
AJCaron12
Jul 23, 2015 09:17 PM
TomekEVO
Jun 27, 2015 07:23 PM
CNOEVO22
Jan 27, 2015 10:59 AM
brandon1304
41
Jul 19, 2012 08:05 PM
