Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Help: Replace O2 Sensor
Old Mar 9, 2011 | 10:24 AM
mrblob20's Avatar
Hi, I have a 2008 2.0L Lancer. Is it easy to replace the FIRST (before cat) o2 sensor? I didn't go right underneath the car, I did a quick oil change, but it was too cold out to look around for the sensor. I have about 145 000 km on it, so I think I'll get some more mileage and performance replacing the sensor.
Is it accessible from the bottom of the car or in the engine bay? Is there cross-members or covers that have to be removed in order to get to it?
Why hasn't anyone done a how to on this yet? COME ON PEOPLE lol.
Old Mar 9, 2011 | 10:39 AM
Jogenmaru's Avatar
The reason no one has done it is because it isn't needed if their are no codes being thrown.
Old Mar 9, 2011 | 04:36 PM
mrblob20's Avatar
ok, so what if I had a code? Now what?
Popular Mechanics says this:
http://www.popularmechanics.com/cars...enance/4219927
It's always the upstream sensor ("Bank 1, Sensor 1") that the powertrain management system pays attention to in order to fine-tune the proper 14.7:1 air/fuel ratio (aka lambda). Lambda is the Greek character used to designate that perfect stoichiometric ratio. And although the modern oxygen sensor has a 100,000-mile life expectancy, when it gets old and lazy you'll begin to notice a drop in fuel economy. More extreme cases of malfunction will lead to driveability issues and, eventually, to an illuminated Check Engine light when the frequency of the sensor's signal slows to a crawl.
Old Mar 9, 2011 | 04:57 PM
yitzac1990's Avatar
if you want to replace that sensor, youll have to either:
a. take to the dealer (expensive)
b. find a 4 wire sensor and splice it in yourself. there is no connector that you can just unplug to release the O2 sensor.
Old Mar 8, 2015 | 06:08 PM
sshoty228's Avatar
hi guys i need help i received a a bank 1 sensor 2 code . The did research different websites have different info . Does a lancer 2009 gts have 2 or 3 sesors ?? and does anyone know the locations . I can see one right at the catalytic is that number 2?
Old Mar 9, 2015 | 09:03 AM
Veronica's Avatar
You have 2 sensors:
Sensor 1 is the primary O2 (for adjusting mixture).
Sensor 2 is the one after the cat - for measuring cat efficiency.
Old Jun 30, 2015 | 03:36 PM
shinobee1's Avatar
thanks
DONNOD
Sep 28, 2016 06:32 PM
babaz7
May 22, 2016 09:57 AM
GodRealm06
Jul 9, 2015 02:36 AM
AbrasEvo
Jun 4, 2009 10:42 AM
xcuzme
Feb 21, 2007 06:55 PM
