Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
drl, fog light, hid
Old May 25, 2011 | 04:10 PM
erunamo's Avatar
Question drl, fog light, hid
09 ES:
the idea: Fog lights behave same way as drl would, on by default after hand break is off. No matter if high beams on/off fog light stay on. Use fog light switch to turn of drl all together. Atm using this bypass to disable drl so i can use hids.
any ideas ?
Old Jul 6, 2011 | 08:52 AM
jguajardo8's Avatar
Originally Posted by erunamo
09 ES:
any ideas ?
I have been looking for months how to do this. I just can not find any write up on this. Hopefully someone can do a write up on this post of point us in that direction.
Old Jul 6, 2011 | 03:09 PM
DMuhny's Avatar
Hmm. So you want your fog lights to automatically be on 100% of the time? Even while using the DRL bypass?
I use the same DRL bypass, but I don't have foglights or HIDs.
Old Jul 6, 2011 | 04:11 PM
erunamo's Avatar
Well yes .
If I can bypass in different location (relay box, computer) then I could route drl to fogs and would not need harness for my headlights
And the idea of switching wiers between fog and head light did pop in my head and was dismissed , if you turn on High beams , fog lights ( in this case would be head lights ) will turn off , and that with out eveN mentioning that the controls of lights will get complicated
Ratedx444
Jul 19, 2016 07:43 AM
jayt27
Aug 14, 2015 06:08 AM
desiromeo812
Jul 5, 2015 03:51 PM
overdrive1
Canadian Forum
Jan 4, 2012 10:52 AM
08GTSMayhem
Dec 14, 2007 08:39 PM
