So I have been having problems locating the clutch bleeder screw from the dealerships. I was given the part number mb555284. I have tried different places like autozone or oriely's for a bleeder screw replacement. Would anyone the measurements for the bleeder screw? Or is there a different part number? Thanks guy.
hi all, i have a 2003 vrx 2.0lt Lancer, my problem seems to be clutch, on and off usually at the traffic lights after shifting into neutral i cannot shift into gear, clutch pedal seems low on pressure, i can find gears after restarting the car however roughly, then all seems fine until next time. anyone else had this problem ?.
james i had same prob bleed your clutch but overfill the master to make sure clutch is getting enough fluid. imo prob with the o3 is internal slave i want to tranny swap so i can have one on outside case
