Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Installing Cruise Control
Old Feb 3, 2018 | 03:24 AM
vimash's Avatar
Hello,
I have a Mitsubishi Lancer 1.5 MT year 2011. I want to install cruise control. The Cruise control switch, brake and clutch stop is all i need and what Ive searched is that I have to enable it through the ECU. I have remove the cruise control cap, and found the blue pin in the steering wheel with wires.
So I want to know if cruise control will work in my car.
Thanking you in advance.
Old Jul 13, 2019 | 10:08 PM
waleedshams's Avatar
You need an ECU from 1.6 ASX, it will work, but you need MUT 3 to reprogram it to your car, or get the full immobilizer set with the ECU
Old Nov 29, 2020 | 02:30 PM
NKTA's Avatar
Installing Control Cruise
Hi.
I'm also interested in installing control cruise on a Mitsu Lancer '09.
Could you be more specific in what is necessary to install CC ? I do have, the clutch + stop switch and soon will have the steering wheel buttons.
I'm following a tutorial i found on web, and Mitsu Lancer ES 09 does have the options on the ECU. Once does options are activated, it should a problem of installing everything.
There's also a pdf containing schematics supposedly from 2007-2010 Mitsu Lancer, but is not complete. It's missing somethings like connectors location, which is very important.
Would appreciate some help.
Old Nov 30, 2020 | 12:35 PM
NKTA's Avatar
Post Installing Control Cruise
Should notice, that the only thing missing is the connection from the switches (clutch and stop) to Auto-Control Cruise ECU. Commands are from button on steering wheel.
Old Jul 4, 2021 | 03:16 PM
NKTA's Avatar
Bumping up and updating topic.
Have fully connected everything regarding to control cruise.
However with the current Engine ECU 1860B170, i can't activate the control cruise. yes both the option for control cruise is activated (or present).
Meanwhile i managed to get another ECU 1860A976 and tried on my vehicule. It manages to activate control cruise, but this ECU is for 1.8 petrol and up. So can't use on my car, as it can't start the engine.
Does anyone know what to do next with teh Engine ECU in order to put control cruise to work ?
Mitsubishi Lancer 2009 1.5 petrol, 4A91 engine CX-CY
ECU 1860B170
MUT3 and OP2.0;
kadykady
Jan 26, 2009 03:13 PM
Diavlo
Aug 31, 2007 02:25 PM
HiRevnVIII
Aug 4, 2005 06:39 PM
chase2000gt
Jul 5, 2005 05:56 PM
