Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How To: Rear sway bar
Old Apr 11, 2008 | 11:13 PM
Blacksheepdj's Avatar
Tools:
12mm socket/wrench
14mm socket/wrench
1. Lift the rear end of the car.
2. Remove the endlink from each end of the swaybar (14mm).
3. Remove the four bolts holding the swaybar brackets to the crossmember (12mm).
4. Pull the swaybar out either end.
5. Your new swaybar should come with it's own bushings. Grease them up (inside and out), and put them on the bar.
6. Slide the bar into place. MAKE SURE you have it above the control arms (I didn't; I had to remove and reinstall the bar to get it right).
7. Put the 4 bolts in that bracket the swaybar to the car. Tighten them to 23 ft-lbs.
8. Put the endlinks on the new bar. Tighten the nuts to 29 ft-lbs.
9. Put rear wheels back on.
10. Lower car.
Attached Thumbnails How To: Rear sway bar-2swayendlink.jpg   How To: Rear sway bar-3swayinstalled.jpg   How To: Rear sway bar-4swayinstalled.jpg   How To: Rear sway bar-1swaybracket.jpg
Old Apr 11, 2008 | 11:16 PM
Discuss this thread here.
Blacksheepdj
Apr 11, 2008 11:07 PM
vegasboy301
Nov 8, 2006 12:26 AM
SiCKlEyWiKeD
Jul 19, 2006 09:57 PM
vegasboy301
Oct 26, 2005 11:17 PM
MitsuJoe
Sep 25, 2005 12:36 PM
