Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How to Swap your ECU...
Old Aug 13, 2009 | 04:32 PM
darkmitsu's Avatar
1. Open your glove box on the left hand side there is a romovable tab...
2. Remove it...
3. grab the right hand side of the glove box and push left to get the tab over
4.
5. open the glove all the way towards the floor and it will pop off
6. grab a hold of the wire harness cover and pull it towards you
7. unplug the ecu
8. remove the three black 12mm bolts
9. the ecu should fall to the floor
10. to remove the ecu from the metal bracket use a flat head screw driver and pry on the outer edge.
11. then reverse to get everything back in...
Old Mar 24, 2014 | 02:15 PM
ratchet889's Avatar
None of the photos are working. Reupload? Could really use this.
Old Mar 24, 2014 | 02:27 PM
pheoxs's Avatar
Same here, can't see any pics.
Make sure they're not private in photobucket or consider using imgur to host the pics.
Old Mar 24, 2014 | 04:30 PM
eusgen's Avatar
I think the written instructions alone are enough guys, this isn't difficult... If you are not sure how to do this then you probably shouldn't be doing it, you could potentially F yo car up people.
Old Mar 26, 2014 | 02:28 PM
ratchet889's Avatar
At the risk of sounding rude, the whole point of threads like this is to provide assistance in properly performing a certain build on your car. Yes, improperly doing it could "F yo car up" which is exactly why I want to have pictures to help.
For example, I can't find the tabs he's talking about in the glovebox. I really shouldn't have to explain more than that. The only reason I'm even looking for help is because I can't find the information in the service manual.
Old Mar 26, 2014 | 04:31 PM
Thahomeboyb's Avatar
Type in "how to change cabin air filter 02 mitsubishi lancer"
You'll see how to to remove the glove box
darkmitsu
Lancer Engine Management / Tuning Forums
141
Dec 31, 2022 05:41 AM
concept11253
Aug 31, 2014 07:14 PM
concept11253
Jul 17, 2014 05:48 PM
mci2727
Jan 30, 2013 10:06 AM
darkmitsu
Lancer Engine Tech
141
Oct 12, 2011 05:13 PM
