Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How To: Install a Evo X ecu on a NA Lancer.
Old Jul 7, 2016, 11:43 AM
  #31
RALLInspired's Avatar
i've developed the ability to disable any and every CEL for Mitsubishi CAN based vehicles, including lancers, outlander, RA, Evo X, and of course, a lancer with Evo X turbo. It requires one of my custom ROMs and tuning.
Old Jul 7, 2016, 06:01 PM
  #32
sebass007's Avatar
That is excellent!
Thanks!
Old Jul 8, 2016, 02:00 PM
  #33
Sleeved4b11Pgh's Avatar
RALLInspired - I tried contacting RRE a few weeks ago and they told me they couldn't do it remotely? Just wondering, how much for a fully custom tune for a 2010 RA 9psi turbo setup on a 2010 Lancer ES 5 speed? I mean base map plus a few pull corrections (remotely)? Which codes are you referring to? MIVEC EX, IAT, Boost solenoids...?
Thanks for everyone's help!
Old Jul 23, 2016, 11:42 AM
  #34
Old Jan 5, 2017, 07:50 PM
  #35
krypt952's Avatar
sebass did you run into any problems with the keys / immobilizer or do you just need to put the VIN in the ECU and it works because the immobilizer info is saved in the ETACS ecu?
Thanks
Aaron
Old Jan 6, 2017, 04:08 AM
  #36
LiX
LiX's Avatar
Depends on how the VIN is written in the ECU. In my case it didn't had any problems, just started.
A friend of mine had to relearn the keys in order to start the engine.... so be prepared if needed.
Old Jan 27, 2017, 06:26 AM
  #37
Dryasme's Avatar
Do you guys know where to install the IAT sensor on the manifold?
Old Apr 16, 2019, 01:11 PM
  #38
Miguel Ortega's Avatar
Cant, tune my Lancer
Grettings
I have a Lancer Turbo with Evo X Rom on it. I buy tactrix cable and download ecuflash. Cant read the ecu for tuning because said (unkown rom image). I have a 2009 ecu.
Anyone can helpme with this problem?
Im new in this. Please help
Old Aug 16, 2020, 08:24 AM
  #39
riyodan_04's Avatar
Originally Posted by sebass007
So you have boosted your lancer...
With the MUT-III, copy the ECU Coding from the Lancer to the PC. To do that, you have to clear the DTCs, if there is one DTC, it will not work. I had to install the IAT sensor because the P0098 was always there and I wasn’t able to clear that code. The P0243, P0242, P0365 can be cleared and if you don’t start the car, they will not show up.
Hi Sebass007, first I wanna say thank you for your posts about your turbo lancer. I also read your posts in project lancer, didn't get to say thanks in that forum.Thank you.
I wanna clarify this P0098 issue bcos in another turbo build it wasn't an issue when he swapped to EvoX issue.
1. Am i correct that you had this code when you flashed an EvoX rom on your NA lancer ECU?
2. Noob question, where and how did you put the 2nd IAT sensor? I can't find a guide on lancer turbo threads.😅
Old Dec 28, 2020, 08:17 AM
  #40
2Raunchy's Avatar
Thanks
Aaron
heya did you relearn the keys to the car did you get it to start?
Old Dec 28, 2020, 08:20 AM
  #41
2Raunchy's Avatar
did your friend have a cranking no start issue
before he relearned the keys to the car
Benja
Oct 15, 2018 06:52 AM
mad-max
Mar 12, 2010 03:28 PM
eiu2b
Nov 25, 2008 09:55 AM
gamebred26
May 12, 2008 06:09 AM
Quick Reply: How To: Install a Evo X ecu on a NA Lancer.
