Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
OEM Bluetooth installation advise help
Old Oct 25, 2019 | 11:16 AM
lasmariaspr's Avatar
I have a Lancer DE 2014, when I purchased I installed a non nav touchscreen radio from an Outlander, I would like to add Bluetooth module but, I only saw the 20 pin connector for the radio and USB plug. There was no connector 18 pin connector, also behind glove compartment I also did not see the plug to connect the Bluetooth module which is secured in blue tape as mentioned in other posts. I don’t have the button steering wheel. Is it still possible to install the OEM module in my car? And if so what do I need. The GROM system is not compatible either. I see in secret menu on radio the hands free option not highlighted because it’s not there. I have a little experience with electrical because I was able to install a aftermarket reverse cámara without the plug. Please advise!
Old Sep 5, 2024 | 08:01 PM
The Renga's Avatar
Bluetooth Lancer
Realicé ese montaje hace un tiempo en mi Lancer 2013, se necesita el módulo Bluetooth compatible con tu radio, el ramal y cableado del módulo Bluetooth, el micrófono que va en el techo( en la luz de cortesía) y el control al volante.
Algo más menos así
Jake26
23
Jan 6, 2022 06:34 PM
TwinDragons
Feb 13, 2014 11:31 PM
heel_touge
Dec 6, 2009 03:03 PM
ColdEvolution8
Dec 14, 2008 06:17 PM
FastAzzEvo
Dec 21, 2007 01:32 PM
