Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Catalytic Converter
Old Feb 2, 2020 | 11:57 AM
steveg77's Avatar
Catalytic Converter
Hello,
First, I don't know a whole lot about cars, so keep that in mind. Anyway, I have a 2010 Lancer GTS. My engine light kept coming on a year or so ago and it's off and on with the 420 code. I finally decided to take care of it and get my cat converter and sensors replaced. I know a mechanic who's been doing this for quite a few years and I went ahead and ordered the converter (front) and the sensors. Fast forward and the mechanic tells me that I don't have a front converter, but just the long pipe running with the cat in the middle. Does that sound correct? When I look up the parts, I get both the direct fit ones with the pipe and the shorter one marked as "front." Is it just located in a weird spot that you normally wouldn't think it should be? Again, forgive my ignorance
Thanks!
Old Feb 2, 2020 | 06:16 PM
bumblebee.4G69's Avatar
5 Year Member
Before you go nuts swapping out O2 sensors a d catalytic converter and the rest
Try this
http://imgur.com/a/l3sDM2f
It might just save you a ton of $ and time
Old Feb 2, 2020 | 06:40 PM
steveg77's Avatar
Right, but the question is, are there two cats, or just one?
Old Feb 2, 2020 | 06:42 PM
5 Year Member
Take a look and see
I haven't seen under the GTS
I would assume.one
Old Feb 2, 2020 | 06:49 PM
steveg77's Avatar
There's certainly a cat on the underside, but I wouldn't really know if there's another one. Would they be pretty close together? The thing that throws me off is that parts stores show two cats for that particular model, but from your answer I gather those Lancers only have the one?
Old Feb 2, 2020 | 06:51 PM
5 Year Member
My lancer 2012 I know for a fact has only 1 Cat in it
It has a 200 cell unit in it
Old Feb 2, 2020 | 06:54 PM
steveg77's Avatar
Okay, thanks for that info!
Old Feb 2, 2020 | 06:56 PM
5 Year Member
Hope it all.works out for you
Keep us posted
steveg77's Avatar
Will do
mikediamond84
May 13, 2010 06:05 PM
katafuji
Lancer Engine Tech
Mar 7, 2008 10:07 AM
Daddymac
36
May 17, 2004 08:21 PM
S.A BLK EVO
Nov 7, 2003 01:35 PM
joseph k
Lancer Engine Tech
19
Sep 10, 2002 04:48 AM
