Basic 2004-2006 Ralliart Audio Info
Old Jun 23, 2008 | 11:52 AM
otter's Avatar
EvoM Administrator
I didn't have an adapter to make the 6.75" speakers fit (they were too big to work with the 6.5" adapters that came with the previous speakers.) Basically, the 6.75" speakers were big enough to sit on top of the hole, but not big enough to reach the screw holes, which is why I used zip ties and foam (to prevent rattles.) At some point I'll go back and make a proper adapter out of 1/4" plywood, but at the moment, I don't really care that much.
Old Jun 23, 2008 | 10:55 PM
ModifiedOne's Avatar
Anyone know where I can find myself one of these? I've looked everywhere!
http://images.importtuner.com/featur..._dashboard.jpg
Old Jun 24, 2008 | 07:02 AM
otter's Avatar
EvoM Administrator
Search the vendor sections for Orbital Kit.
Old Jun 25, 2008 | 08:58 PM
Talking
Thank you! Finally!
Old Aug 26, 2008 | 07:10 AM
snakoil's Avatar
could someone provide the wire color for the speakers on a 06 RA without S&S
I need to know wich one is + and wich one is - as I think is inverted them for one speaker
Old Aug 29, 2008 | 03:55 PM
gary_06ralliart's Avatar
Here you go....
12v constant- red/black
Ground- antenna, just plug your antenna in
Ignition- blue/yellow
illumination- green/white
power antenna- yellow
left front speaker...+red/white -red/blue
Right front speaker...+red -green
Left rear speaker ... +white/blue -yellow/red
Right rear speaker... +lt.green -yellow/green
Old Sep 3, 2008 | 06:19 AM
snakoil's Avatar
are the speaker wire color the same at the speaker end?
I saw some toyotas where the wire color was different at the HU then at the speakers
Old Sep 3, 2008 | 12:03 PM
most of the time the speaker wires are different at the speakers actually, if you need those colors i can pull the diagram at work tomarrow
Old Sep 5, 2008 | 05:26 PM
RalliDew's Avatar
What is the diagram for hijacking the stock amp and powering an aftermarket amp to run a single sub i happen to have some stuff laying around and am rusty on audio system but have never jacked into another amp to power another exe. pm me or answer here thanks
Old Sep 5, 2008 | 06:38 PM
otter's Avatar
EvoM Administrator
The stock amp should only have two wires going to the sub, should be easy to figure out.
Old Sep 7, 2008 | 12:11 PM
RalliDew's Avatar
do i need a LOC for that or ???
Old Sep 7, 2008 | 03:42 PM
you only use a line out converter if you are trying to put an aftermarket amp in. a line out converter will just convert the signal and let you use RCA's for an aftermarket amp. you can just use the pos. and neg. wire that plug into your factory sub. you can take those and hook them up to the aftermarket sub, but the power and ohm load will be wrong and it won't sound that great...
Old Sep 9, 2008 | 04:53 PM
azt021's Avatar
is it just the bezel or a lcd radio with the bezel and hvac relocation bezel?
Old Sep 9, 2008 | 07:36 PM
that is just a dash kit that comes with a hvac relocation kit. its an expensive kit though and hard to find. usually runs about $300. the radio can range anythere from $600 to $1400
Old Sep 10, 2008 | 05:37 PM
azt021's Avatar
wow, ok im going to have to look around and rig some thing to move hvac! i want to add a gps, but do not want it on the wind shield. i would like it where the hvac is at. if something come to mind i will add pics and a how to! so far i have added a dome light with skulls hanging down above the rear view mirror! tuff but fun!
