Question regarding ohm ratings
Will I have any problems if my amp and sub do not have matching ohm ratings? It's been years since I've done any stereo work and I'm a bit rusty on the basics...any input/recommendations would be appreciated
If the speaker resistance (ohm) is too low, you risk overheating/killing the amp if it can't handle it. Most sub amps these days are just fine at 2 ohms, and many will run at 1. 4 channel amps are usually only okay with 2 ohms if they're bridged, 4 ohms unbridged.
Assuming your sub is single voice coil (SVC), yes! Now, if we'd got more complicated and thrown a Dual voice coil (DVC) in there and wired it in parallel and not series...the amp woulda had a problem!
But at the mentioned setup (SVC) you'll be golden. I ran 2 12" JL W0s off my Kenwood 4-ch bridged. Ran well for 6 years until both subs blew within one week! LOL Still using the amp to this day in my current setup. Oh how quality has gone through the window!
so your SVC woofer @ 4ohms will be bridged to 1 channel@4ohms mono, which roughly is the same total amount as 2 channels @ 2ohm stereo.
only the woofer determines the ohm load, an amp can run any ohm load that a speaker presents to it, but actually handling it is a different story.
Since you haven't bought anything yet, you will easily be able to match outputs and ohms to your preferences. You can pick whichever one you'd like to then base the other decision off of the rating or wiring options (if you choose a DVC).
ImJoey
Jun 27, 2007 04:05 PM
