S & S Infinity amp
Old Mar 30, 2009 | 05:53 PM
Androcalypse's Avatar
S & S Infinity amp
so i am planning on upgrading my speakers soon and was wondering since i have the sun and sound package and the person before me took out the infinity amp and sub before it was sold to me, if that actually affects the quality of my speakers now
or rather if i get an amp now, would it make my speakers sound better because maybe i lost some of the quality due to the missing amp? just wondering if anyone knew thanks
Old Apr 4, 2009 | 04:47 PM
majestic*'s Avatar
I'm assuming you have an aftermarket headunit and the previous owner didn't know how to integrate the factory amp OR had their own aftermarket amps in the vehicle before selling the car to you and rewired it.
Most likely, you're speakers are wired directly to the aftermarket radio which means they are most likely getting a full range signal and maybe 18wrms if that.
Depending on your definition of sound quality, I would recommend aftermarket high amp to give you more clarity, control and volume and if you want more mid bass or sub... then add a sub amp and subwoofer(s).
Post more info on your current setup, what deck you have, what speakers.
Hope this helps,
Nick
Old Apr 6, 2009 | 01:17 AM
thanks nick for the info
yeah i have the alpine idax200 ,16W x 4 RMS power/45W x 4 Max power,
well i guess u basically answered my question cuz im going to go find an aftermarket amp for my speakers and btw my speakers are the infinity speakers 180w or something
but thanks again
Old Apr 10, 2009 | 03:46 AM
majestic*'s Avatar
No problem... the X200 should have a built in high pass filter (HPF) in the audio setup that will allow you to filter out the lower frequencies which will give you more usability out of the system before getting into clipped signals or distortion. This would be a good start before amplifying at least.
You will lose your midbass the higher you go in frequency... I believe the options are: 60hz, 80hz, 100hz, 120hz... try all of these and see what works best for you for the type of music that you listen to.
Even with the filter on though, understand you are still only outputting 16wrms to each speaker which isn't much by any means... if the speakers are aftermarket and can handle 180wrms then look for an amp to run them... but consider what the amp can do as well: built-in crossover, regulated power supply, class a/b/d?... don't be afraid to put power to your front end... 80% of what you hear in your vehicle comes from the front speakers.
Many amp manufacturers are making class d full range amps now... putting 150+ watt rms to each speaker ... with the right speaker of course.
Hope this helps,
Nick
Old Apr 20, 2009 | 07:43 PM
alright that helped nick
now im just looking around for an amp
thanks for the info
Old Apr 21, 2009 | 09:05 PM
majestic*'s Avatar
No problem... I can suggest a few... JL Audio Slash Series (300/2, 300/4), HD Series (600/4, 750/1, 800/5), TMA (360.2), Alpine PDX Series (2.150)...
hope this helps.
scothu
24
Dec 20, 2010 05:09 AM
Eildydar
16
Aug 24, 2007 12:22 AM
matute
Sep 19, 2006 08:26 AM
datdjrobp
11
Sep 21, 2005 07:24 AM
Evo8nut
Jul 24, 2005 12:09 PM
