help with stereo
Old Apr 24, 2013 | 09:49 AM
This Guy's Avatar
help with stereo
so i replace my stock stereo with a alpine cde-137bt single din and used the wire harness adapter for the stock amp and sub and it sounded good at first but after i replace my battery it sounds like it doesn't bump as much as it use to,
Any ideas on settings for the aftermarket stereo? or is my amp going out? i can hear and feel bass from the sub when i put my hand over it but doesn't sound as loud.....
Old Apr 25, 2013 | 06:07 AM
Veronica's Avatar
hmmh. Check the body to the battery ground.
Check the radio head unit for 'loudness' or some other bass volume feature and for output levels. I would re-read the manual for settings that were wiped out. I do not belive it is the amp/wiring adapter...
Could the amp or the speaker be failing? Possible - but check the other stuff first.
Newuser213
Jul 27, 2014 02:52 AM
Webman
105
Feb 4, 2013 07:23 PM
This Guy
Jan 18, 2013 07:05 AM
Sweetness1892
Jul 13, 2010 07:49 AM
streetracerkam
Sep 12, 2009 09:36 PM
