Increasing my sound?
Old Oct 31, 2013 | 01:41 AM
Newuser213's Avatar
Just got a used ES and the system/speaker are weak!
Is there any way to increase the volume/sound without
changing the factory stereo system? I kind of want to
keep the FUSE system. Maybe replace the speakers
and add a amp and subwoofer??
Old Oct 31, 2013 | 04:39 PM
02ES=>09RAL's Avatar
You to get more power to the speakers...with out blowing them, of course.
I added a 4 channel amplifier to the stock door speakers.
Sounds so much better now that the speakers are getting
a proper amount of power to them vs. the internal amp on the stock head unit.
They cleaner sound
Old Nov 2, 2013 | 08:23 PM
Newuser213's Avatar
Anyone know if the 2012 OEM lancer radio headunit can be used with a
aftermarket amp? What kind of connection does the OEM unit support?
Old Nov 3, 2013 | 03:49 PM
kpr10is's Avatar
Almost no OEM head units have direct preout connections for amps, but any aftermarket amp can be used. The aftermarket amp will either have direct speaker level inputs or you use a line output converter to convert the factory speaker wires into RCA outputs which feed the signal to the amp. You can tap all of this behind the radio, no need to run new wires except for from the radio harness to the amp.
Old Nov 6, 2013 | 02:32 AM
Newuser213's Avatar
I was just worried that a aftermarket AMP cannot be connected to the OEM headunit. I wanted to keep everything pretty much same but use my own AMP and new speakers and add a subwoofer maybe.
Old Nov 20, 2013 | 11:36 AM
08lancerr's Avatar
I had the same problem in my DE. When I bought it, one of the speakers was (and still is) blown, and the right side speakers are much louder than the left side. I checked the balance and options and the left side is just super quiet. I just ordered all new speakers hoping to get better quality. As for the amp problem, I will just have to wait to play around with the new speakers and see if they are balanced and louder.
Thanks for the info.
Old Jan 9, 2014 | 08:16 AM
08lancerr's Avatar
To get back to this,
I installed new Kenwood speakers, and the volume/weakness issue is fixed! It is not a problem with the amp, just crappy stock paper speakers. Hope this helps!
Old Jul 27, 2014 | 02:52 AM
ardenalpha's Avatar
new speakers would be the quickest option i would have thought, next id change the head unit (unless you want the dash to look stock) as aftermarket headunits have a higher watt output so that will increase volume. If these 2 options still dont satisfy your needs then ether buy a amp and power the door speakers from that or buy an amp and a decent subwoofer - if you can give up some boot space ofcourse!
brianbrase
Outlander Sport
23
Mar 27, 2015 05:37 AM
deanmeon
11
Jul 16, 2014 08:32 PM
sgtboost
Sep 24, 2012 07:03 PM
WWGSR11
81
Dec 27, 2011 06:57 AM
toyotabike
29
Oct 13, 2010 10:04 AM
