Mudflaps
Old Dec 12, 2004 | 09:51 PM
noriceoz's Avatar
Mudflaps
would the evos mudflaps fit on my lancer
Old Dec 12, 2004 | 10:11 PM
acs_guitars's Avatar
They should... would require you make some holes on the inner wheel well is all.
Old Dec 13, 2004 | 06:07 AM
Centrylancer's Avatar
i need a set sooo bad
Old Dec 14, 2004 | 08:03 AM
Mike@Accolade's Avatar
yes they will fit with a little modification to the underguard.
Old Dec 14, 2004 | 03:21 PM
Blacksheepdj's Avatar
Yes, but you need to make some changes. I know the Rally Armor ones that Mauro sells in the Evo forums should fit, but you have to drill the holes out a little.
Old Dec 14, 2004 | 04:00 PM
OZLancerlunatic's Avatar
mud flaps for what? show off that rally! get that stuff all over your doors and windows!
Old Dec 14, 2004 | 04:36 PM
Nah, REALLY show off that rally! Get the huge tacky mudflaps!
Old Dec 14, 2004 | 04:37 PM
twardnw's Avatar
heh, I got a shovel, we can just fling mud on it, saves wear-and-tear on the car
Old Dec 14, 2004 | 04:38 PM
machron1's Avatar
Will it really work? Evo wheel wells are deeper than lancers, so I'd worry they may stick out a bit.
Old Dec 16, 2004 | 05:02 PM
Shingen's Avatar
The flaps are supposed to stick out a bit. If you think about it your tires aren't always straight. When you turn for instance. I'm not being a smart a$$ but the flaps are suppose to stick out from the side of the car to stop dirt and mud from flicking up.
Fox
PS- check out my mudflaps. I didn't buy the Evo ones either. But some consider them rice.
Old Dec 16, 2004 | 07:25 PM
Trooper's Avatar
Shingen thats why my car gets so much mud on it
Old Dec 17, 2004 | 01:47 AM
machron1's Avatar
Fox
That's actually what I meant. The mud flaps for the Evo stick out a bit, and that's with wide fenders. On the normal lancers it seems like it would stick out excessively. Maybe you can trim the material?
Old Dec 17, 2004 | 10:31 AM
Yes, trimming the material is an obvious and easy solution.
