Quick Question about Reverse Indiglo Guages
What the hell is a digital inverter??? Ther chage $15 for it so im wondering what it does. Thanks Guys heres a link to guages.
http://www.streetracerparts.com/inde...OD&ProdID=1421
In my opinion, digital is not worth it, analog you get a nice little knob to change the brightness, and a switch for blue or green... you'll turn it blue because the green looks like ****.
Oh, be careful after you've installed with the inverter and want to change the color, even while grounded, putting your hand on the back of it sends a few volts through you, mmmm like peeing on a wire
Originally Posted by KAOTIK
ive done that a couple of times just gotta find somewhere to put the damn thing
i don't think its worth it. its just one more part that'll prob. go out and you'll have to replace. the knob is good. the only plus i see is if you got a bunch of different color choices with the digital one.
ever seen that show "mythbusters"? they tested that myth about being electrocuted if you peed on an electrified wire, & since pee kinda starts breaking off into little drops by the time it hits the ground (no continuous stream of pee), the electricity cant reach you.
"It's like peeing on a hot wire from an inch away"
