Re-wired signal lights =D
Old Nov 15, 2008 | 12:15 AM
  #46
OZ Rally's Avatar
I want to do this too...
So instead of getting a resister, relay, etc, you just added extra wire and it worked fine?
Old Nov 15, 2008 | 12:22 AM
  #47
ThunderOZ's Avatar
pretty much. Has been working fine for about a year now... I also have the mirrors with the turn signals so that may be effecting it as well...
Old Nov 15, 2008 | 07:45 PM
  #48
JP Neon's Avatar
Originally Posted by ThunderOZRacer
Did you cut out any of the wire? Believe or not, when I rewired mine, I added some wire. It blinks like normal now...
yes, I have a new set of wires hooked to a switch next to the interior light switch for the daytime running lights...
the front turn signal wires went to the side marker lights...
and the side marker lights are covered with electrical tape...
are you suggesting that I try to put dummie lights on the taped off set of wires to off-set the electrical load?...
if so, that's a helluva idea that will most likely fix it... (i shoulda came up with that)
gonna try it tomorrow and see what happens... thanks
Old Nov 15, 2008 | 08:01 PM
  #49
ThunderOZ's Avatar
I think I need a pic of what you are talking about... Side markers lights covered with electrical tape? Also, if you disconnected a turning light, that'll make it blink faster too.
Old Nov 16, 2008 | 01:14 PM
  #50
Dermy's Avatar
i did the same thing to my OZ a couple weeks ago. all i had to do was find an 1157(dual filament) socket and harness, then i wired the bright filament wires into the existing wires running to the signal (power and ground) then i jumped the power wire for the dim filament over to the corner light harness. now my signals up front stay lit as parking lights, and flash for signals as they originally did. took me all of 10 minutes to do and it looks great
Old Nov 16, 2008 | 02:06 PM
  #51
ThunderOZ's Avatar
I didn't even think about doing it that way, I just made them constants...
Old Nov 16, 2008 | 03:23 PM
  #52
ES_02's Avatar
ok i rewired my lights so my daytime is turn signals now and they blink too fast... i hate it.. how big of a resistor do i have to solder in to fix it???
Old Nov 17, 2008 | 12:42 AM
  #53
JP Neon's Avatar
...Side markers lights covered with electrical tape?...
basicly the wires that go to the parking lights on the side are taped off and not used in my turn-to-daytime set up...
I'll get a pic as soon as I can...
Old Nov 17, 2008 | 01:09 AM
  #54
ThunderOZ's Avatar
Well that may be why they're blinking so fast... It basically acts as if you have burnt out bulb...
Xshieldsx
Jul 31, 2018 05:06 PM
EGbeater
23
Apr 20, 2015 10:46 AM
vietxscapeD
Jul 10, 2006 06:31 PM
vietxscapeD
Feb 1, 2006 12:28 PM
vietxscapeD
West Region
Dec 20, 2003 07:38 PM
