Engine Paint
Old Mar 24, 2003 | 07:24 PM
BoricuaMIRAGE's Avatar
i say, powder coating or air brushing...
Old Mar 24, 2003 | 07:39 PM
OZevoVII's Avatar
i like the anonized (sp?) paint, it looks metalic and way more professional. i think it is a lot more expensive though? Kontra has it.
Old Mar 24, 2003 | 08:58 PM
yeah, that cost about twice as chrome plating!!
Old Mar 24, 2003 | 10:08 PM
ciaxtrinity1's Avatar
Dupli Color Engine Enamel www.duplicolor.com
Resists temperatures up to 500 degrees F or
Dupli-Color® High Heat Paint with Ceramic
Resists temperatures up to 1200 degrees F
Old Mar 25, 2003 | 06:06 AM
mark2002lancer's Avatar
can you buy powder coating in an autobodt supply store
Old Mar 25, 2003 | 07:50 PM
lol... powder coating is a system used for metals... antirust,high heat etc... the way some one powder coats is 1.they strip the metal debris with some liquid, 2.then they transfer electricity to it, 3.then the use special paint to spray it on 4.after that it goes into an oven where its cooked at a high temperature...
a powder coating system runs about 1200+< you also have to have some basic knowledge on painting and mixing colors as well as the amount of electricity passed/ and type of metals etc...
Old Aug 30, 2009 | 05:41 AM
demodeakin's Avatar
Im going to Give my Engine and Transmission a Paint Job this weekend. I hope that the Paint holds up to Oil and Grease this is the only time I plan to have the engine out of the car while I am out here in Guam.
Old Aug 30, 2009 | 06:03 AM
ct78155's Avatar
Originally Posted by J'sLancerLS
Well, I recently worked with some parts that were powder coated and the coat peeled back and flaked off were there was heat being applied. I'm certainly not a pro with coating, just what I've seen with my own eye's.
Sorry to inform you, but your parts were not prepped correctly if this happened.
Powder coating will withstand more heat than paint, and is 10 time more durable than any paint.
There is no paint liquid, it's ALL powder. Also there in no mixing required
To the original poster, I would recommend some high temp paint as powder coating the block CORRECTLY can cost you a pretty penny. If you prep everything correct, the paint will hold up well to the bay heat.
___
Carlos Tirado
Tirado Custom Coatings
Old Aug 30, 2009 | 09:01 AM
BrandonShaw's Avatar
Well the OP posted this about 6 years ago... hopefully he's found his answer by now lol
Old Aug 31, 2009 | 09:57 PM
davidmitsusrock's Avatar
QFT
Old Sep 1, 2009 | 06:58 PM
lancer2show's Avatar
___
Carlos Tirado
i noticed you powdercoat. theirs a new kind of technology where you can mix the powder and dissolve it into liquid. have you heard of techline coating?
Old Sep 1, 2009 | 09:16 PM
hcj's Avatar
hcj
here is mine i did a few years back with regular paint
i know it is not the best paint job but it was made with regular spray paint
paint never came of
Old Sep 1, 2009 | 09:20 PM
hcj's Avatar
hcj
here are some examples of power coating part
(not my car pic from different members)
Old Sep 2, 2009 | 06:53 PM
Daedalus2051's Avatar
those are some beautiful pieces, too bad powder coating is so expensive or i'd love do give my engine some color. god knows its gonna need bath in grease cutter before any part of it could go anywhere near paint haha.
Just out of curiosity... what is the correct way to prep say the valve cover to be painted?
mobman
Jan 29, 2010 10:38 AM
ILovE WHEELS
Apr 8, 2008 12:28 AM
Tree
13
Jan 9, 2008 06:06 PM
08Lancer89
47
Sep 7, 2007 12:08 PM
Babblingsponge
Mar 7, 2003 11:11 AM
