custom lancers
Old Dec 23, 2003 | 10:54 PM
jon_e_blaze's Avatar
custom lancers
well basically, i have been tossing around a few ideas for some custom work on my lancer. my plan is probably going to envolve some serious alterations to the rear seats (i'll probably just take them out all together ) and some seriously custom speaker set up. although i'm still not exactly sure what direction i will go, i was wondering what kind of custom work everyone else has done with their lancers. i'm just curious more than anything, but i would like to see where the imagination and ***** have taken other lancer owners. i know juiced02lancer was working on some ****, but he's gone m.i.a. anyway, let's see what you guys have got. pics would really kick ***.
Old Dec 24, 2003 | 01:59 AM
03_OZ_LancerBoy's Avatar
Well, I've got alot done and alot more to get done...will have pics soon...I've got the Apex Version I kit, Arospeed Double Deck aluminum wing w/wing extension, tyc elegante carbon fiber taillights, VIS carbon fiber hood, lowered, shaved door handes and gas tank door, molded rear doors shut, custom molded door panels in the rear, 7 inch screen molded in passenger side dash, roof scoop, molded in side scoops, fender flares to give off wide body effect...more to come...theres just some ideas though
Old Dec 24, 2003 | 02:30 AM
jerzepnoy's Avatar
sounds good man .. but how u supose to fill up?
Old Jan 6, 2004 | 09:35 PM
so no one's done anything custom to their lancers. or are you all just keeping the good **** to yourselves.
Old Jan 6, 2004 | 09:38 PM
rentaslut's Avatar
im relocating my cruise control and putting in a wheel from tekniqauto.com =)
Old Jan 6, 2004 | 09:43 PM
sweet. where you gonna put it? that's awesome, it would solve the issue of losing cruise with a new wheel.
Old Jan 6, 2004 | 10:04 PM
Titaztik's Avatar
I'm going to check around at some shops and see if any one can make a Carbon Fiber OEM Front Lip molded from the OZ Lip...and if that goes well then also do the side skirts and rear lip also but I still have to check and see if any shop is up to the task and REASONABLE ( that is the main thing )
That is just something I've thrown around
Adam
Old Jan 6, 2004 | 10:27 PM
that would look freaking sweet. i don't know why no one makes cf lips for our car anyway.
Old Jan 6, 2004 | 10:50 PM
JWERNER24's Avatar
In Timeout
I have a couple custom ideas im keeping to myself until I figure out if they will work or not...
Old Jan 7, 2004 | 08:42 AM
Drive02Lancer's Avatar
LnacerBoy u better take some pics of all that **** man, that sounds crazy!
you said u shaved ur gastank...how are you gonna fill up? lol
boba has a crazy setup in his trunk and even has a sub in the passenger foot well area.
Old Jan 7, 2004 | 01:02 PM
evofan@scorp's's Avatar
I've been thinking my stock OZ wing is too low, but I don't want an E7 or E8 wing. I've always liked the wing on the 2.5 RS, so I was thinking of sculpting some plastic risers to lift the wing up and give it a beefy look. I've been sketching out various shapes, and it really would not be that hard to do. I think the only hard part would to be to get both risers the same dimensions and shape, the middle post will be the easiest. I'm only thinking of 1/2 inch rise at most. After everything is perfect, I'll have a shop attach the risers, and bondo the seems, so it looks perfect!
Anyone know where I can get blocks of light weight plastic? I've been into sculpting most of my life, so fabricating this will be easy and fun!
Old Jan 7, 2004 | 01:22 PM
pgmike's Avatar
i really want wider fenders. id like to somehow custom fit jetta fenders onto our lancers, but this would probably cost way too much.
Old Jan 7, 2004 | 02:16 PM
2hot4u's Avatar
I would like to have carbon fiber lips and finders!
Old Jan 7, 2004 | 02:50 PM
SORRY THAT I HAVENT GOTTON BACK TO YOU GUYS...I HAD THE GAS FILLER RELOCATED TO THE TRUNK AND HAD CUSTOM ALUMINUM DIAMOND PLATING LAID IN...ILL LATER HAVE MY AIR RIDE COMPONENTS MOUNTED IN THERE...THE CAR IS STILL IN THE SHOP GETTIN WORK DONE IN KEMNER...I JUST MOVED TO AUSTIN (TX) AND THE SHOP IN KEMPNER IS LIKE 4 HRS FROM HERE NOW SO AS SOON AS I CAN ILL GO UP THERE AND GET SOME PICS...TILL THEN...YALL KEEP UP N KEEP THE RIDES CLEAN
Old Jan 7, 2004 | 03:03 PM
pgmike's Avatar
you arent supposed to use all caps. just telling you so you dont do it again and get yelled at by a moderator.
