How to Install JDM Headlights
Old Jun 27, 2011 | 07:46 AM
  #151
LancerBri1120's Avatar
For the low beams I have a 6000K HID kit so would it be the same setup?
Old Jun 27, 2011 | 02:03 PM
  #152
OZR_Lancer's Avatar
dont have any hid's
Old Jun 27, 2011 | 02:10 PM
  #153
Originally Posted by OZR_Lancer
dont have any hid's
Whats the color layout for turn signals for both sides. For some reason my blinkers still dont work even though we wired everything right.
Old Jun 27, 2011 | 02:31 PM
  #154
OZR_Lancer's Avatar
your likely gonna have to make a hid kit work.. rember a 9007's is a hi/low single bulb thats stock for our cars. thats why theirs a 9007 plug for one bulb that is for the oem housing and the inner spot is ur turn signal on oem housing
jdm cedias are dual beam setup 9005 for high [ inner ] and h1 for low [ outer ]...
Old Jun 27, 2011 | 02:33 PM
  #155
OZR_Lancer's Avatar
the turn signal blinkers should be a seperate cable thats comming from the main harness.. if u follow the cable run you will find that theirs 3 leads.. 1 is for turn signal, 1 for amber sidemarker and 3rd is for the headlight
Old May 2, 2014 | 07:01 PM
  #156
Bcuzlancer's Avatar
Alright so i am a beginner at electrical. I am alittle confused reading through this thread. I ordered the headlights and am waiting for them. Cant wait to get them. But i also ordered h1 HIDs along with the adapters that it comes with for $10 extra. Something about dual in dual out. Idk haha i ordered them from ddmtuning. It comes with the h1 harnesses. So i should be good on the low beams now, right? Or will i need to order those adapters from the outlander as well?
Now for the high beams, i need to get 9005 harnesses and bulbs, not sure where to get the harnesses to be honest haha but ill check rallylights for the person that mentioned the site. So once i do that, will i then be good with the high beams?
For the parking lights, i understand there are 2 parking lights on each cedia headlight rather just one on each like the usdm lights. But i am not sure what wedge type bulb to get for them. I just need 2 more because i want to stick with the amber color. What will i need for the parking lights?
For the turn signals, from what ive read, the ones on the oem lights will just go right into the turn signal area on the cedias? Anything i need?
just need some help. And is there a way to do this without changing the 9007 plug so just incase i can switch back to my oem lights? I will be doing this with some help too cause i do not want to **** up any electrical **** with my car
Old May 19, 2014 | 09:41 PM
  #157
Bcuzlancer's Avatar
Forgot to post but my headlights actually came like a week ago. But they came with bulbs in them and all the harnesses. Literally is plug and play. Havent gotten them in yet though. But i looked and there is a plug that im pretty sure the oem turn signal plug plugs into a plug on the headlight that powers the 2 parking lights and the signal. It doesnt fit into it. And there are only 2 prongs inside for connecting wires while the new headlights have three prongs inside the plug so i wont be able to connect that to the stock wiring how it is. So im gonna have to figure something out with that harness. But the high and low beam are already wired up and plug right into my 9007 plug. Even tried it and both the low and high work. Was really nice to see that they came with harnesses and bulbs for the high and low beams. Gonna need to get 2 parking light bulbs
Here is the harness for the 9007. just the high and low beam together
Then the other harness for the 2 parking lights and the signal light
The headlights are actually pretty decent quality and the harnesses are done nicely and the wires are all covered and siliconed in the plugs
Attached Thumbnails How to Install JDM Headlights-image-3376326705.jpg   How to Install JDM Headlights-image-387506813.jpg
Old May 21, 2014 | 02:19 AM
  #158
mco-evox2008's Avatar
please pic
Old Aug 14, 2014 | 10:13 PM
  #159
Bcuzlancer's Avatar
Nevermind it was actually pretty easy once you figured it all out. They look good and i love the high beams. Love these lights
johnjonfenomeno
178
Jan 7, 2026 09:18 PM
afeudale
157
Nov 9, 2016 02:49 PM
EvokidIX
Mar 12, 2016 04:08 PM
EGbeater
23
Apr 20, 2015 10:46 AM
gt40
Oct 11, 2004 12:22 PM
