How to Install JDM Headlights
Old Oct 6, 2004 | 04:28 PM
LancerXtreme's Avatar
So the H1's are the Low Beam Right Guys???
Old Oct 6, 2004 | 04:56 PM
azyan's Avatar
H1 Low Beam
9005 High Beam
Old Oct 9, 2004 | 09:14 AM
Thanks bro. Just finished ordering my H1 8000k HID's now. Cant wait to get and install now. Up next week, Evo VII Tail Lights.
Old Mar 9, 2005 | 06:49 AM
Pick_a_Fro's Avatar
so wait...do we need an H1 harness?
Old Mar 9, 2005 | 06:58 AM
OZLancerlunatic's Avatar
Correct, if I am reading correctly you will need an h1 harness and 9005 harness. Each harness should have 2 wires, ground and power. Use the ground on each harness, splice them together and attach it to the headlight harness ground. This leaves 1 wire on each bulb harness and those will connect to the wires on your headlight harness in the car. Very simple install.
Old Mar 9, 2005 | 10:11 AM
twardnw's Avatar
I think the H1 harness is just 2 female spade connectors, I'll know later today, I'm picking up the parts so I can install my new housings
Old Mar 9, 2005 | 11:27 AM
Pick_a_Fro's Avatar
i wish I can take a digipic of the back of the headlight housing....cuz the place where you put the H1 bulbs...the hole has a white plastic plug with 2 copper prongs sticking out of it...so do u not put in a bulb in that spot? is there a bulb in there already?
twardOZRally, please update us on ur progress. I'm having trouble following these instructions. Call me a noob i don't care...this is why i made this seperate thread ... https://www.evolutionm.net/forums/sh...d.php?t=126737
also let me know how much those harnesses cost and if u could take a pic of them or wut not.
THANKS! I really wanna put mine in already!
Old Mar 9, 2005 | 02:19 PM
twardnw's Avatar
mmkay, I'm on my way to the auto-parts store now, probly won't get to install for a few more weeks though, but I'll be ready
Old Mar 9, 2005 | 02:23 PM
lookslikeanevo's Avatar
that plastik socket is where the bulb goes, you will connect a negative and a positive to those prongs, no there is no bulb in there already. so you have to buy one. This was a real hard install for me also, took me like 3 hours to figure everything out on the first light, and like 30 on the next one, just get a volt meter and test the wires
Old Mar 9, 2005 | 03:45 PM
Pick_a_Fro's Avatar
finally someone says it's a hard install...everyone sayin it's easy...pllleaaaassee.
so that plastic white thingy...it's pretty stiff, does it come off or does it push in when you put the bulb/prong H1 thing in there?
Old Mar 9, 2005 | 03:46 PM
twardnw's Avatar
I just got back with all the parts, I'll test fit them and take some pics for you
Old Mar 9, 2005 | 03:51 PM
Pick_a_Fro's Avatar
I luv u 4 dat man. EVOM ROCKS!
I'm so glad I brought this thread back up from the dead !
i'm sooo close to takin those headlights out of the closet and onto my car .
also how much did those harnesses run u?
Old Mar 9, 2005 | 04:19 PM
twardnw's Avatar
here's that little housing for the H1
assembled (I had to loosen the tabs inside it a little to get the bulb in)
use the 'handle' circled in red to open up the wire latch
9005 bulb installed
9005 bulb + harness (the harness was only about $5 ea.)
Old Mar 9, 2005 | 05:24 PM
Pick_a_Fro's Avatar
thanks,
twardOZRally...now that's how u do it.
I say make an entirely new HOW-TO with pics
I'm gonna buy my parts tomorrow and might get crackin on it HOLLA!
Old Mar 9, 2005 | 05:26 PM
twardnw's Avatar
well, the parts total was 87.77, and I bought cheap H1's, I'll probly go back and get some name-brand ones
