How to Install JDM Headlights
Old Mar 12, 2006 | 07:37 PM
  #61
iyi0521's Avatar
love these lights
Old Mar 12, 2006 | 08:53 PM
  #62
SJ's Avatar
SJ
i have HID kit with 9007 (just low beam)
if I buy H1 HID bulbs then does it come with harness and everything that i need to fit in cedia lights housing?? or do i need socket things? (i know i need 9005 harness too)
Old Nov 11, 2006 | 09:11 AM
  #63
PGDlancer's Avatar
Originally Posted by twardnw
The turn signal bulb sockets are different on the cedia housings, it is possible to temporarily use the old bulb, but I wouldn't suggest that long term.
Might be a dumb question, but what bulbs are supposed to be used for the cedia turn signals if the stock bulbs aren't right??
Old Nov 11, 2006 | 09:40 AM
  #64
Iamkar33m's Avatar
They're wedge bulbs. Forget what number it is though but i think they're similar to the rear turn signal bulb.
Old Nov 13, 2006 | 06:10 AM
  #65
Kurt's Avatar
I used the bulb out of the stock housings turn signal.
This is kind of a n00b style question, but what is the difference between the 9005 and 9005XL other than the base?
Old Nov 13, 2006 | 10:29 AM
  #66
Iamkar33m's Avatar
Larger bulb? XL = Extra Large
Old Nov 14, 2006 | 05:23 PM
  #67
iyi0521's Avatar
the cedias use an offset single contact bayonet style of bulb for the turn signals
Old Nov 14, 2006 | 05:33 PM
  #68
PGDlancer's Avatar
Whatever works for you, but mine are fine. The stock turn signal bulb is working just great ......
Old Jun 9, 2007 | 04:35 PM
  #69
imajinmyfx's Avatar
sorry to big back this thread but i decided to go back to reg bulbs instead of hids... i bought h1 bulbs but they wont fit in the harnesses (i have a new set of wires b/c i have two sets of cedias) dp i need to buy a harness for h1 bulbs?
Old Jun 9, 2007 | 05:33 PM
  #70
Iamkar33m's Avatar
Yup... you need a set of harnesses for the H1 bulbs, also i forget which bulbs are the high beams. 9005 or 9004 i think.
Old Jun 9, 2007 | 05:34 PM
  #71
Iamkar33m's Avatar
Low beams: H1
High beams: 9005
Old Jun 9, 2007 | 05:36 PM
  #72
imajinmyfx's Avatar
damn you kareem!! .. i was waiting for you to get on aim. i had my laptop outside with me while i was trying to install just an hr ago... i'm like "wtf, these bulbs won't connect" haha. it got late so i'll do it tomorrow
Old Jun 9, 2007 | 05:41 PM
  #73
skylancer's Avatar
Yeah, you will need harness for both high beam (9005) & low beam (H1)....the stock harness (9007) is totally different so you will need those to wire them to your stock harness!!
Old Jun 9, 2007 | 05:46 PM
  #74
imajinmyfx's Avatar
cool, thanks .. i have those for the hi beam. i just want to remove the hids and put standard bulds instead.
Old Jun 9, 2007 | 05:57 PM
  #75
Iamkar33m's Avatar
Actually, if you want you can wire straight to the prongs of the H1 bulb... but it is recommended you use a harness as straight wiring can easily throw a short. If you do decide to wire straight to the prongs, it doesnt matter which prong gets positive and which gets ground... just be sure to wrap it in electrical tape or shrink tubing.
