jet washer neon lights [MERGED]
Old Apr 4, 2004 | 12:20 PM
ls787's Avatar
Question jet washer neon lights
hi, i recently purchaserd the ket washer lights for my lancer, does anybody have detailed instructions on how to install them..
it comes with a small switch so i dunno if i should connect it directly to the battery or to my night lights..
can someone pleasse give me some instructions on how to put these lights on, plus on how to take the original black jets off.
Thanks alot.
Old Apr 4, 2004 | 12:26 PM
LancerEvoMR's Avatar
Moving to USLG. The How To's Forums are only for direct step by step how to's, not questions.
Old Apr 4, 2004 | 12:41 PM
younggotti's Avatar
just off the original washers off and screw the new ones on.....then connect the red to a power source and ground the black one
Old Apr 4, 2004 | 01:17 PM
ls787's Avatar
Thanks alot.
Old Apr 4, 2004 | 01:21 PM
rentaslut's Avatar
I've got some instructions, throw them in the garbage
Old Apr 4, 2004 | 01:28 PM
lanceryellow's Avatar
i would connect the switch too so you can turn them on and off cause cops like to pull you over for haveing them on
Old Apr 4, 2004 | 01:33 PM
SK Lancer's Avatar
Garbage. Definately garbage.
If you dont know how to put on wiper LED's, throw them out.
Old Apr 4, 2004 | 01:53 PM
h8yourv8's Avatar
Dude definentily through them away. It was cool for about 2 weeks, now the only ppl that have 'em are rednecks. Way to ricey, even for the ricest of Civics out there. Don't put 'em on a Lancer.
Old Apr 4, 2004 | 01:54 PM
rentaslut's Avatar
put them to use.
use the LED's from them under your seats.. for sex lights.
Old Apr 4, 2004 | 02:01 PM
Kid Lancer 7's Avatar
Rice Patty!!!!!!!!
Old Apr 4, 2004 | 02:21 PM
jaymz916's Avatar
Again, more useless info given to somebody asking a legit question by a bunch of people with the "I'm the car guru" mentality, and wasting space in a thread in the process.
Dude, if you want those on your car, only your opinion of them matters. It's simple, First you pull the washer hoses of the oem sprayers form the underside of the hood. Then, you simply have to pull or pry the oem sprayers out of the hood, they're just press fit in there, careful not to scratch the hood! Run the wiring next, I don't know which kind you got, but you usually have a 12v, a ground, a relay of some sort and your switch. Depends on how you want to run them. If you want them to turn on with your headlights, just tap the power going to your headlights with the 12v line. If you want to turn them on/off independently from any oem light, just tap 12v form the battery and run it to the switch. (Also, do all this with the neg. cable disconnected!) After the wiring is all hooked up, positive, neg, and switch, the new sprayers should have nuts and washers with them. Put em in, tighten everything down (not too tight, they are plastic) plug the washer hoses back on, reconnect the battery, you should be good to go. Honestly, just follow the instructions that come with them, they're pretty self explanatory. You can pm me if you have further questions. Good luck!
Old Apr 4, 2004 | 03:31 PM
ls787's Avatar
thanks alot jaymz916
i dont kno if there overused where u guys are but dont see much of those lights here in the tdot.. especially not on civics..
ez
btw amazing lancers on the site!
Old Apr 4, 2004 | 03:33 PM
Drive02Lancer's Avatar
yeah i dont see that many here...i see more on hooked up trucks than cars actually. i thought about some blue ones...but ima wait til i get a blue under body kit and than ill get the blue washer lights.
racingguy13
Jul 13, 2011 10:20 PM
newcomer81
20
Oct 26, 2009 05:43 AM
ItalyIX
Aug 13, 2007 10:06 AM
MysticMyth
Jun 30, 2004 08:37 PM
morphcivic
Aug 12, 2003 08:46 PM
