Shift Knob Problem
Shift Knob Problem
I got an Ichibahn shift knob that uses the three screws and the rubber sleeve to hold it on. I kept having to tighten the screws like every day and now its at a point where the screws can't be tightened anymore but the knob is still loose and can actually be turned completely around. Does anybody have any advice on how to get the knob working or is it pretty much useless now?
well what the knob does is essentially dig the screws into the rubber sleeve to form a seal, only problem is the screw hole gets stripped or the rubber keeps on changing shape.
well... kartboy has some for the lancer... and evo... but it's not really my type... i have a knob... what i did was drill a hole in the the inner rubber... just big enough so i can twist it over the threaded part of the shifter... this causes it to be tight and bite onto the shifter... this might help
TWM Performance
Evo X How Tos / Installations
Sep 12, 2013 09:07 PM
hytek369
14
Jun 26, 2008 12:13 PM
