Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
here's an odd one...
Old Sep 6, 2005 | 03:19 PM
datdjrobp's Avatar
driving around saturday afternoon i felt a little chatter in the steering wheel. nothing major, just a little left/right rocking as i'm driving. figured i should check my tire pressure since it had been a couple of weeks.
Front L: 16psi
Front R: 44psi
Rear L: 26psi
Rear R: 26psi
now, according to my handy dandy manual, fronts are supposed to be at 29psi... so 15psi or so somehow moved from my front left to my front right. odd. air in the left, air out of the right, drives like a champ again. a little concerned though, might change out the front two tires.
Old Sep 6, 2005 | 03:22 PM
Lil red '03's Avatar
wow - that IS wierd.
Maybe you didn't replace your summer air with winter air yet ??
Old Sep 6, 2005 | 03:50 PM
Xshieldsx's Avatar
Haha damn I bet that was an uncomfortable ride.
Old Sep 6, 2005 | 10:09 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
It is possible that you turned left a lot during you drive, causing the right tire to increase pressure, although that is a bit much. As for the other side, maybe it has been losing pressure, or you moved it off the rim just enough (while cornering, or hit a bump or curb) to let some air out. Other than that, do you have any enemies or people wanting to pull a prank on you? Or happened to have driven through the Bermuda Triangle?
btw, nitrogen fluxuates much less if you ever want to try inflating your tires with that. Problem is if you have to adjust later, you might not have nitrogen around. That's what they use in NASCRAP though, and it was disturbing to see a pit crew guy letting pure nitrogen out of some tires while sitting over the wheel smoking a stogie!!!
Old Sep 11, 2005 | 03:14 AM
RumbleCam's Avatar
um.. correct me if im wrong but isnt nitrogen mostly inert? at least in relation to flame? isnt the atmosphere like 80 percent nitrogen?
Old Sep 11, 2005 | 10:55 AM
Zippo41189's Avatar
I use the nitrogen from my scuba tank to fill my tires. I don't need to adjust NEARLY as often. It helps if your lazy like me though.
Old Sep 11, 2005 | 05:46 PM
Moderator
Bomb Squad Unit #02
I guess I had nothing to worry about then
Old Sep 11, 2005 | 08:39 PM
RumbleCam's Avatar
lol
well i was just hoping that i was right and not making a fool out of myself lol
akride907
Mar 17, 2016 02:13 PM
JDMevoBOOST
Sep 8, 2011 03:01 PM
Incognito
For Sale - Part Outs
125
May 2, 2009 07:28 PM
bluej20
Mar 28, 2008 06:29 AM
evolucionado
Apr 11, 2003 04:41 PM
