cross drilled rotors
okay i had question im in store for new rotors on my 'es' but i was thinking about cross drilled , okay i thought since cross drilled have less metal on them (since theres holes in them ) wouldnt that make them lighter ? so if there lighter there would be less weight on a turning part which would make my car pick up a bit quicker?
DO NOT get cross-drilled or slotted rotors. Cross drilling is old tech for pads that
gas a lot, you don't really need them with todays better designed brake pads. Slotting is to remove the glossed layer of brake pad from repeated heavy braking and very little cool-down. Unless you are racing on a track you don't really need either. Just get a good set of solid rotors. If you must spend lots of $ then get nice 2 pieces rotors that are aluminum in the center so that you save some weight.
i got some slotted rotors because i autox with my lancer--but i had no interest in drilled and a quick search answered any questions i had about why they aren't right for our cars.
however the OEM rotors are a good choice as well--my friend who also autoxs runs the stock rotors and they have been great for him.
just some other stuff to consider for the OP.
