Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Programming Tire Sensors
Old Jul 27, 2007 | 12:29 PM
the_cosworth's Avatar
I am looking at purchasing the stock 18's for the GT-S's instead of other rims (keep it stock looking while I put my cash into the drivetrain) but was told by mitsu that they need to program the sensors so the computer will recognize them. Seeing as the mitsu dealer is 55 minutes away and has the worst hours known to man.
Does anyone know if I could activate/program the sensors for my car myself? and if so how?
Old Jul 27, 2007 | 01:05 PM
Blacksheepdj's Avatar
Just get your stock sensors put in the new rims. According to the owners manual, those sensors should last 5 years (which means they'll really last 10... ).
Old Jul 27, 2007 | 01:32 PM
I was hoping to have both sets work because I am keeping my stock 16's for winter tires and would rather not have to get them continually swapped back and forth.
are there any reasons that I couldn't run the winters without the sensors in them?
Old Jul 27, 2007 | 02:23 PM
The only reason is the massive annoyance of the TPMS system going off CONSTANTLY. If you don't mind that, then go right ahead. But from the folks that have put on tires without TPMS, it's been a nightmare of bonging and flashing warnings on the INFO screen.
Didn't know you meant a 2nd set, sorry. I was hoping you'd come trade wheels with me and we could just switch sensors.
Originally Posted by Elvis077
You can run wheels and not use the tps.. It just pulls up Every time you start the car.. then after about 10 seconds you have to hold the Info button til it goes away, then every time you open the door it reminds you again.. Every time. I went for about 4 days when my rims were off getting powder coated and I wanted to shoot someone... But maybe that's just me. (Don't do it)
Old Jul 27, 2007 | 03:38 PM
if you want to drive to vernon sheep I will trade you straight up. I am on call and cant leave within an hour of Vernon until September
Old Jul 28, 2007 | 07:09 AM
I don't know what state Vernon is in.
I probably wouldn't do it straight up anyhow. But thanks for the offer.
Old Jul 31, 2007 | 12:18 PM
Rabidhamster's Avatar
... could just swap the sensors back and forth from your rims.. or get a second set and reprogram them every time you swap rims/tires
you can only program the sensors you are using into the car at a time. and even if you could program all 8 into the computer.. the second your car moved like 10 ft away from the sensors.. the reminder light would light up and blink
easiest way would be just to swap your sensors back and forth each season change. shouldn't even have to take the tire off the rim, just pop the bead and push the edge down , pull the sensor out,
as for programming yourself.. it's not something that you can just fiddle with the ign and locks/door open close (theres some cool stuff you can turn on and off with toyota's if you know the sequences ) .. you have to go into the ECU itself and input the sensors serial codes one by one ... I haven't checked the global scanner to see if it can, but I'm pretty sure you need a manufact specific tool to get in and set the sensors
Old Aug 27, 2007 | 08:09 PM
AeJarrotto's Avatar
or just do like a dude over on Lancertuners.com said. Throw them into a chargeable air container, fill it to the correct pressure and throw it in your trunk. lol
Old Aug 27, 2007 | 09:37 PM
Uh, that was on here.
DannyMR
Feb 27, 2023 03:12 PM
TPMS N.G.S.
Vendor Classifieds
173
Jun 13, 2018 08:39 AM
packrat
149
Apr 28, 2018 07:59 PM
sterlinge
Jun 20, 2016 08:23 PM
Brent_si
May 11, 2012 09:36 AM
